regreasing starter: how much grease?
Old Dec 29, 2010 | 09:49 AM
eFLO's Avatar
my starter has been making some noises now that it is getting really cold so i am going to regrease it and see if that helps it.
how much grease do i actually put back in there? just enough that everything is covered, or really pack it with grease?
Old Dec 29, 2010 | 12:06 PM
asand1's Avatar
I packed quite a bit of grease in there with no ill effect. That being said, with good grease you dont need a whole lot, so you can use "enough", or "alot". Just put a good coating on each gear and bushing and youll be fine.
Old Dec 30, 2010 | 02:19 PM
eFLO's Avatar
ok i ran across something that had slipped my mind.
i have a grounding kit and i had removed the bolt that runs through the starter and connected a wire to that,so instead of taking the starter apart today i tightened that bolt a little since i think it may have been a little loose.
i figure that since that bolt holds the starter together any play may cause the parts to vibrate and create the sound. may be a long stretch but now that i think of it the noise started happening after the installation of the kit.
hopefully that solves it!
Starrider
Sep 17, 2015 07:26 AM
Bonka
Sep 14, 2015 11:18 PM
SusieQQ
Sep 9, 2015 12:14 PM
RealityCheck
Aug 5, 2015 06:18 AM
Curt Deiner
Oct 31, 2001 08:05 AM
