How to take off Front Wheel Hub?
Old Jan 17, 2011 | 07:58 AM
mpvibes's Avatar
Does anyone know how to take off the front driver side wheel hub without using a slide hammer? Any other tools that I can use? I know how to take off the wheel, brake rotors, axle nut etc. Thx.
Old Jan 17, 2011 | 09:49 AM
luke95gxe's Avatar
remove wheel,remove the 2 nuts and bolts that hold the strut to the wheel hub remove brake pad and caliper there ar 2 bolts on the back of the wheel hub to remove the pads and caliper as one unit and then remove the rotor ,remove the tie rod and remove the nut that hold the wheel hub to the ball joint remove the big nut int the center of the hub(the axle nut)and bam ur done
Old Jan 17, 2011 | 10:17 AM
tigersharkdude's Avatar
Go to FA.PDF and scroll down to page 8
1997 Maxima FSM PDF
Old Jan 17, 2011 | 11:08 AM
mpvibes's Avatar
Thanks for the help!
mpvibes's Avatar
1997 Maxima FSM PDF
Thank you, I will be saving this!
HOKUSMAX
Nov 13, 2017 04:34 AM
AnsonJ
Jun 2, 2017 01:35 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
twotonezed
Aug 16, 2015 11:41 AM
BassAddictJ
Aug 4, 2015 11:38 AM
