Harmonic balancer issues
Old Dec 9, 2012 | 01:21 PM
  #41
tre2k4's Avatar
Im trying to take this bolt off myself and, just to verify, in what direction should the bolt on the HB be turned in order to loosen it. Also, if I use air tools, how much power I need from the compressor in order to loosen it up.
Old Dec 9, 2012 | 02:51 PM
  #42
asand1's Avatar
The bolt needs to be turned counter clockwise. If you don't have big enough air tools use a breaker bar against the floor AHEAD of the crank shaft, or the sub-frame BEHIND the crankshaft and bump the starter.
Old Dec 10, 2012 | 10:29 PM
  #43
tre2k4's Avatar
Im assuming I do the setup 1
I tried it several times and it was a no go. Do I take my car off the brakes to do this?
Old Dec 11, 2012 | 07:00 AM
  #44
asand1's Avatar
What have you tried, and what has been the result? The video I posted always works for me. Don't waste your time trying to hold the balancer from turning.
Old Dec 11, 2012 | 07:41 PM
  #45
tre2k4's Avatar
The torque wrench plus engine crank was tried several times and now it wont crank all the way. Battery is dead. Tried electric impact gun, we will try something more powerful tomorrow hopefully
Mar 12, 2020 12:06 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
dcam0326
Sep 8, 2015 11:02 PM
