1157 led replacement bulbs question.....
Old Feb 28, 2011 | 03:21 PM
max ride 41's Avatar
so i was thinkin of replace stocker 1157's with the led version of these. you know, these...http://cgi.ebay.com/ebaymotors/2x-13...Q5fAccessories anyone used these???? will they look that much brighter in the stock housings??? thanks>>>>
Old Feb 28, 2011 | 03:32 PM
JNCoRacer's Avatar
Just the tip.
Ive used them before. Pretty decent. Check with the seller. That listing is for 1156's.
Old Feb 28, 2011 | 04:11 PM
you got any before and after pics??? i really want to see them at night. i was just using that listing for a reference anywho.
Old Feb 28, 2011 | 06:35 PM
DennisMik's Avatar
JNCoRacer is right, those are 1156 type bulbs (BA15S). 1157 type bulbs are BAY15D. The seller spends a lot of words telling you how great of a guy he is but he never tells you the light output of those led lamps.
Old Feb 28, 2011 | 07:33 PM
i was also wandering because of the light's output being led should i use a little bulb grease when putting these in?? i've never taken out the rear bulbs before, is there a simple way to get them out w/o breaking those little clips??? and, the ones on the trunk, i only see 1 wire, is that the brake light, thanks and pics would help.
Old Feb 28, 2011 | 08:30 PM
schmellyfart's Avatar
Are you using these to replace your brake lights or turn signals? I don't remember which bulb goes to what.. I have similar red smd led bulbs in my rear turn signals (DIY Red/Clears); they are pretty bright at night, but they are a little difficult to see in the daytime.
Old Feb 28, 2011 | 09:51 PM
just the brake lights, i want to see pics if someone has them.
Old Mar 26, 2011 | 09:41 AM
bent9's Avatar
I purchased some of these on ebay. Not this seller. But I was not terribly happy with the brightness. I am going to purchase another set but this time go for one with more bulbs (15).
Old Mar 26, 2011 | 09:56 AM
pics when u get them in dude, day and night. thanks>>>>
Old Mar 26, 2011 | 11:26 AM
Maximar's Avatar
1156s are used for turn signals and reverse lights as they only need one brightness level, and 1157s are used in the brake lights and corner lights at the front since they vary in brightness. If you put them in the turn signals make sure they have enough resistance so they don't burn out your relay. I have LEDs in the brake lights and reverse lights and im pleased aside from the fact that i should have used red LEDs so they didn't turn pink but, they're ok. Actually less bright than conventional bulbs but, unlike conventional bulbs they reach full brightness instantaneously while, conventional bulbs take a second to warm up.
Old Mar 26, 2011 | 12:37 PM
VisciousMo's Avatar
Hmm, I hear good things about superbrightleds.com
KristyKarina
Aug 23, 2015 09:53 AM
spidgeon
Aug 18, 2015 05:46 AM
220k+ A32
Aug 17, 2015 03:57 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
