Rear Wheel Spacers
Thanks, I ordered mine through Pann Auto in San Diego http://pannauto.com/
Another reason for using wheel spacers is to increase the handling of your vehicle. Wheel spacers are installed between the hub and the wheel and push the wheel further away from the chassis, widening the track. This is turn increases the amount of grip that your vehicle has in corners, allowing faster cornering. Spacers can also change the balance of your car's handling. For instance, if you install spacers in the back but not the front, then you will get more grip in the rear. This in turn will cause your car to understeer, where the front goes towards the outside of the corner, during cornering, because of the increased grip from the rear.
Huttig2009
Sep 25, 2015 03:31 PM
