Factory alignment settings?? Anyone know? Detailed image inside, Please help here->
I whacked a curb on passenger side while back. Alignment got whacked as well. Steering wheel about 45 degrees to the right to drive straight. I needed new axles anyway up front so I changed those out, didn't notice anything bent or out of norm while servicing. Took it to Tire Kingdom to get alignment w/print out of final readings. The problem is I don't know how to compare these readings to what the factory readings should be. I need to purchase a camber kit to correct the camber on the passenger side due to the impact damage- that goes without saying. Take a look at the results and please let me know if I should take it back to correct anything. Thanks.
especially after I specifically told them what happened.
If I had to bet, I'd say the LCA is bent. Here's the alignment specs for a 97. I don't know if all 4th gens are the same.
Camber
Degree minute (Decimal degree)
Minimum −1°00' (−1.00°)
Nominal −0°15' (−0.25°)
Maximum 0°30' (0.50°)
Left and right difference 45¢ (0.75°) or less
Caster
Minimum 2°00' (2.00°)
Nominal 2°45' (2.75°)
Maximum 3°30' (3.50°)
Kingpin inclination
Minimum 13°30' (13.50°)
Nominal 14°15' (14.25°)
Maximum 15°00' (15.00°)
Total toe-in
Distance (A − B) mm (in)
Minimum 1 (0.04)
Nominal 2 (0.08)
Maximum 3 (0.12)
Angle (left plus right)
Minimum 5.5' (0.09°)
Nominal 11' (0.18°)
Maximum 16' (0.27°)
Wheel turning angle - Full turn
• Inside
Minimum 36°00' (36.00°)
Nominal 39°30' (39.50°)
Maximum 40°30' (40.50°)
• Outside
Nominal 32°00' (32.00°)
Camber
Caster
Kingpin inclination
Total toe-in
Minimum 1 (0.04)
Nominal 2 (0.08)
Maximum 3 (0.12)
Nominal 11' (0.18°)
Maximum 16' (0.27°)
• Inside
• Outside
Camber
Caster
Kingpin inclination
Total toe-in
Minimum 1 (0.04)
Nominal 2 (0.08)
Maximum 3 (0.12)
Nominal 11' (0.18°)
Maximum 16' (0.27°)
• Inside
• Outside
Camber
Caster
Kingpin inclination
Total toe-in
Minimum 1 (0.04)
Nominal 2 (0.08)
Maximum 3 (0.12)
Nominal 11' (0.18°)
Maximum 16' (0.27°)
• Inside
• Outside
The info is from the Nissan FSM (Factory Service Manual), section FA - Front Axel, page 26 in the 1997 manual. I don't know what year your car is, but the page numbers will vary in different year manuals.
If you need to download a manual, Go here -
http://www.nicoclub.com/FSM/maxima/
The file named fwd.pdf is the chapter index file for the manual.
The file named idx.pdf is the alphabetical index file for the manual.
All in all, I have never heard of a place that does alignments that does not have the specs. They have to have them because every make and model car is different.
But they probably can't get the adjustment in spec because car manufacturers don't build that much leeway into the adjustments. To get real information when a car has been damaged, you have to go to a a frame shop, a place that repairs accident damage. They have people that are trained in suspension and don't walk around with their heads stuffed up their butts.
thanks again. unfortunately, i think most people in this area all have their heads up their butts no matter what their profession....not the most educated of areas lol...unless it involves duct tape, super glue, and some velcro, cuz we all know if that ain't gonna fix it, nuthin' is! thanks for the help
Do all the bushings while you're doing LCA's (if they haven't already been done), and if those end links are looking tired get both of them along with ball joints, you'd be surprised how awesome the front end of this car can feel....
MR2 T'd
07-09-2021 05:06 AM
MaxLife17
06-27-2019 01:37 PM
