Need help bad
Need help bad
Hey 4th gen bros....I have a huge issue. I currently have the 4th gen upper and lower manifold (stock) on my 1999 Nissan Maxima. I took them out to start my 00vi setup. When I found out I couldn't do to a few missing parts...I put the stock parts back on. I had to cut 3 hoses, but went and bought new hoses to replace them (they fit, i made sure)
Now when I start my car it runs for about 5 or 6 seconds then shuts off. And I smell a good amount of fuel burning. I'm obviously getting fuel, but something is not mixing to run like normal. I am decent with mechanical stuff...but it's just not making sense.
Anybody dealt with this before? I need my car running!
Make sure everything is plugged back up, if you are not getting any codes it could be an iacv valve connection issue or fuel pressure issue. Double check your fpr vacuum connection.
We believe it is a Vacuum leak...however I've unbolted and bolted the stock parts back up, and by "we" 5 guys that also know about cars and what not....nobody has been able to figure it out. Honestly...we believe the issue is so minor, but having no luck.
The car will stay alive by playing with the throttle.
If the engine is dying quickly, that tells me the vacuum leak is large. Mine would run for several minutes before sputtering out. Did you replace any gaskets or just re-use the old ones? Did you tighten everything per the FSM? Sorry if you answered those questions already.
Somebody smokes, give them a pack of cigarettes and start blowing the smoke into the engine bay, get a good light and follow the smoke.
If there is no vaccum leak, which honestly.. If there was the engine would most likely Race Not Die, You need to start with the coils, pull them one by one, than move onto the fuel system.
But as im sitting here I remember my first 00VI swap. Its either your EGR, or your Throttle Body.
Did you try what I said and Pull the Codes or unplug the MAF and start the car?
Yeah, I need to mess with the coils...i've already pulled them out, but i'll give them another look. And as far as the fuel system goes, I haven't touched it except for removing one hose, but I'm 100% sure I put it back on right. So that's not an issue. I'll look at my EGR...but I haven't messed with it either except for when I unbolted it from the UIM, I've rebolted the same way.
Thanks for your input bro, but I won't let anybody smoke around my engine
Honestly. Pull off the Entire Upper Again and redo it all. Seriously its not that hard. You dont need to go crazy with all the connections just ReSeat the Manifold.
RealityCheck
10-02-2015 06:34 PM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
