So it's not a coil pack....it's much much worse...F Me!
Old Jun 1, 2011 | 04:04 PM
VTonmymind's Avatar
Mmm, fresh lobster
Pulled some codes a while back.
6 slows and 5 fast (0605) Cylinder 4 misfire
2 slows and 1 fast (0201) Ignition coil and power transistor
3 slows and 4 fast (0304) Knock sensor
After pulling that madness, I got myself a coil pack, 6 new platinum plugs, a knock sensor and a fuel filter for shyts and giggles.
After dropping my rig off hoping these goodies would make her right as rain, they didn't. Popped the coil pack in and 6 plugs and nope. Mech did a compression test and it was low as *****. Could have bad valves or rings he said. For all that it takes to fix that, might as well get a new motor, he added. shyt...really? Hmmm.
Any idea's as to what else it could be before I start exploring shyt canning the car for parts or getting a new motor (which I'm not to keen on, as I'd just rather get another car with AWD as I live in snow country)
thanks for any help or insights you can provide me with.
Old Jun 1, 2011 | 04:27 PM
asand1's Avatar
Get w second opinion on compression or do it yourself. If its low, the first mechanical is correct. Low comp is rings or valves. Either way, its cheaper to get a motor.
Old Jun 1, 2011 | 05:05 PM
VTonmymind's Avatar
Mmm, fresh lobster
Roger that. 2nd compression test on the order. If it fails again though....guess it'll be time for a little soul searching. All in all the car is in great shape.
What do you y'all suppose I can get for her in this state if I don't wanna go down the new motor road?
Old Jun 1, 2011 | 05:56 PM
Blackwind's Avatar
milage?
Old Jun 1, 2011 | 06:38 PM
maxed_out_99's Avatar
A for sale sign
It's really not worth it IMO
3.5 swap da biotch
Old Jun 1, 2011 | 07:22 PM
VTonmymind's Avatar
Mmm, fresh lobster
Originally Posted by Blackwind
milage?
Bout to turn 150K
Originally Posted by maxed_out_99
A for sale sign
3.5 swap da biotch
Yup, could 3.5 that ish but would it be worth it? Not up here. The stock torque right now is good in the winter. Beef it up, it'll be too much up front and might as well get an AWD drive, which by the way, I'm craving like a ****. say either in the form of a subaru legacy GT or an infiniti g X.
Old Jun 1, 2011 | 10:22 PM
ef9's Avatar
ef9
Screw compression test, I would do a leakdown test.
Old Jun 2, 2011 | 03:34 AM
VTonmymind's Avatar
Mmm, fresh lobster
Can you further explain please
Old Jun 2, 2011 | 03:55 AM
VTonmymind's Avatar
Mmm, fresh lobster
Oh and after said leak test would I basically arrive at the same conclusion (that I need a new motor) or could it be something else?
Old Jun 2, 2011 | 06:10 AM
cashoit's Avatar
find a used motor for 300 or 400. Drop it in for another 200-300. Boom 600 bucks u back on the road with a younger motor.
Whats the problem here???
Old Jun 2, 2011 | 06:51 AM
asand1's Avatar
A leakdown test will tell you whether its the rings or valves. Either way a used engine will be cheaper. You will be paying more diagnostic to get more info than u need.
Low comp=new engine
njmaxseltd's Avatar
Numbers?
Old Jun 2, 2011 | 06:21 PM
Bout to turn 150K
mmmm legacy GT what year?
Old Jun 2, 2011 | 07:03 PM
IslandMax's Avatar
When doing the compression test, squirt some oil into the spark plug hole, if it helps then its bad rings (oil seals them a little when you squirt it in). To check if its the valves, whichever cylinder your checking, spin the motor so the intake and exhaust valves are both closed (cylinder is top dead center) and put some pressure in the cyl through the spark plug hole. If you hear air leaking through the intake then the intake valve/s are bad, if you hear the air leaking through the exhaust then the exhaust valve/s are bad.
Old Jun 3, 2011 | 12:04 AM
ef9's Avatar
ef9
Just do a leakdown test. If it's the valve seals, just replace the heads, you don't need to replace the entire motor.
Old Jun 3, 2011 | 08:51 PM
VTonmymind's Avatar
Mmm, fresh lobster
Originally Posted by njmaxseltd
Numbers?
right around 25. Low as *****.
Old Jun 3, 2011 | 09:04 PM
VTonmymind's Avatar
Mmm, fresh lobster
kinda warming up to the new gens (10 and 11) but can't go wrong with 2005-2009
very helpful, thank you
how much do you reckon replacing the heads would cost?
Old Jun 3, 2011 | 09:57 PM
FallenOne's Avatar
too much. work. time. money.
New VQ.
Just drop in a new 3.0 with something like 20-100K and call it a day.
I'm going to be doing a compression test soon here.. I think 430K miles is all mine's got in her...
Old Jun 4, 2011 | 12:27 AM
ef9's Avatar
ef9
I'm sure you can get some decent heads for $200 or less.
Swap them in yourself, save you a ton of cash.
Old Jun 4, 2011 | 12:09 PM
VTonmymind's Avatar
Mmm, fresh lobster
I think I may be straight up done with her. Had her for a good 6 years and she has done real good for me. Have been wanting to get into something new though ever since moving back up to VT.
So...if I were to sell her straight up..what do you suppose would be a fair price to ask for her?
Old Jun 4, 2011 | 03:49 PM
asand1's Avatar
Not cost effective. Replacing the motor is easier and cheaper than doing a valve job or even head gaskets on a VQ. That means more down time and work for the DIYer, and more money (hours) at a shop. Gaskets are expensive from what Ive seen, a machine shop will have to re-cut the seats in the head, and dress or replace the valves. Not cheap. A lower mileage motor is $450.00 tops.
Old Jun 4, 2011 | 03:57 PM
asand1's Avatar
Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
Plus gaskets $287.73 from courtesy, NOT WORTH IT!!
You also have to drop the oil pan, pull the outer timing cover, timing chain and sprockets, and inner cover.
Thats if the rings are good.
Old Jun 11, 2011 | 05:38 AM
VTonmymind's Avatar
Mmm, fresh lobster
New VQ.
How much of a plug and play is the VQ 3.0?
Old Jun 11, 2011 | 05:45 AM
VTonmymind's Avatar
Mmm, fresh lobster
Stupid question..sorry..meant to refer to the 2000-2001 A33 DE-K motor v. our DE.
Old Jun 12, 2011 | 03:30 PM
Xfactor22's Avatar
DAMN
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
