95 vs 97 ECU
95 vs 97 ECU
why does the 97 ECU suck compared to the 95...my moms 95 revs so much faster and the speed limiter crap isnt there..why does nissan have to do this..make the car look nicer but run worse...das gay...can u swap a 95 ECU to a 97??
Re: 95 vs 97 ECU
Re: 95 vs 97 ECU
now here's the answer: let's say that both cars are identical cars other than model year and the changes that came along. same mileage, same service schedule, same tires and wheels, same everything. the 97 is heavier and has more OBD II (emmisions) restrictions.
that's a simplistic answer. the real answer can be one of millions. dirty throttle body, dirty fuel/oil filters, different gas, different tires, different wheels, different models (GXE vs GLE, etc), different mileages, different throttle cable tensions... a billion different things.
Re: Re: 95 vs 97 ECU
watch out man.. then they are going to complain about you in the feedback forum that you are mean to newbies
Originally posted by dko
why do people never search or read the stickies...this has been discussed so much it has become disgusting...why do you have to do this..post but not search...das "gay"...can you learn to do things yourself?
alright *******s...im sorry that when i DID search, nuthin that suited me came up in the search...and for yur info, i do have a 97 SE...im sorry im being rather grumpy but i havent had a great week...sorry to bother u people
i do have a 97 SE
i do have a 97 SE
I have a 97 SE and it does not have a speed limiter..just like sprint said. it may be hard to get past the 120/125 mph mark, but if it is a SE there is not a limiter.
If you have a 97SE and find it hard to get past 120 mph, then that car needs maintenance, ESPECIALLY the fuel filter. Get it replaced.
DW
DW
DW
DW
SuDZ
Originally posted by black97max
I have an 1997 SE and I have a speed limiter. Shuts off at 118.
B) your car is not an SE
SE's never came with Speed Limiters
Does it shut off, or just kinda lose it's breath, so to speak?? If I were you, I'd do the maintenace 1st before I go the ECU route. It's cheaper that way, too.
DW
DW
DW
DW
Originally posted by SprintMax
A) your car ECU has been switched with a GXE ECU due to an accident or dealer..
I just checked my paper work and my window sticker. My car is defiantly an SE. I have my orginal ECU out right now becasue I have a 95 JWT ECU in my car now. Is there any way to check the 1997 ECU vin number to determine if its an SE ECU? I am curious to see if it is actually a GXE ECU.
Yep that was me. Ever since I talked to you at island drag I have been thinking that I probally have some kind of manufacturer defect. I am going to check my 97 ECU and will let you know what I find. I think your right that somebody had one to many beers when they were building my car
For those who don't know, all Maximas that are not SE's with the Security and Convenience Package have limiters. The Security and Convenience package included "H" rated tires. All other cars had "S" rated tires. This probably seems strange. S&C SE's can obviously go faster than their "H" rated tires are rated for. It would have made sense if they used "v" or higher rated tires. What was Nissan thinking?
The limiter isn't set by years, only by the equipment on the car. As far as the 95's are faster than 97's, this is a false. There are definitely production differences bewteen cars. Some are stronger than others. My 97' ran a 15.210 @ 92 100% stock with only 3 runs all night. I didn't even get to work on the launch or shift points. Andi's 98'(now Paul's) only ran a 15.9 stock. I had extensive discussion with JWT about this. From what they looked at, the maps are essentually the same. The differences are in the 3rd O2 sensor readings and the diagnostic information. Robert(Biomax) dynoed his car with both a 95' and a 97' ECU and there was no difference.
Keep in mind the self learning in the computer will also make a big difference in how the car feels. Try clearing the self-learning and see if performance improves.
no its not false.. the 95 maxima is the fastest of all 4th Gen's.. its lighter.. and it has less emmision restrictions.. if you think 15.2 stock is impressive.. you obviously havn't seen VeeTec or Neal's stock numbers.. 14.7 and 14.8 respectively
Originally posted by VQdriver
if i replace my 97 gxe ecu with an earlier SE ecu will my check engine light come on? does anyone know where i can find used ECUs?
http://www.car-part.com
Nissan did that to keep costs low. All the manufacturers do that anyway. By the way, only some GXEs are limited, not "all Maximas that are not SE's" . SEs and GLEs are not limited.
DW
DW
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
QueensMAX
09-15-2015 04:14 AM
