major OIL LEAK any ideas
Hey guys i got my maxima last night..well the guy last night covered it up pretty well.......I got it home and while the car is running i have this oil leak that just keeps dropping oil...errr...i have no idea on what it is...but its pissing out oil...i dont know if its the oil pump,oil pressure switch, or just something plain wrong....
cant really trace it cant tell where its coming from all i know is on at bottom at the front of the motor......i called the guy who owned the maxima and he said he got a quote from a mechanic to get fixed and they reckon its a split seal....what seal at the bottom would cause this????i will get pics in the morning....
Chances are if it's actually pouring oil, then the oil pressure switch. They can get pretty bad. The last one I replaced (on my beater) pissed about 4 quarts in 10 minutes while idling.
Take the front right wheel and the splash guard off so you can see the front of the engine. Hose the entire thing down with two cans of brake cleaner to get all the residual crap off. Have someone start the car while you watch to see where the oil comes from.
well i am taking it to the mechanic who fixes this maxima.....the previous customer always went to this mechanic...so i think i will take it to him...he reckons its the crank seal....going to degrease it before it goes to him....so hopefully it gets all fixed up and ready to go by the weekend...dropping the car off their on thursday morning....
we have a million seals on our engines, i had my front and rear valve cover gasket done and its leaking even quicker cause i think the dip$hit forgot to put the rtv in, or not enough, or the wrong kind. id rather swap a new block in than replace all the seals that are leaking on my engine right now.
alright i finally had a good look under the car....im almost 100% certain its the crank shaft seal.....i turned the motor on and off and had a look...the leak is coming right in between the crank pully and timing case....
well the guy i bought it off kept moving locations on where i was looking at the car...he had a good sales technique which i fail for...which i am also a sales man but for construction equipment...plus i got the car for cheap in australia these maximas especially the 30GV as its the fully optioned with everything...and he had receipts for everything it has a brand new water pump, new active suspension ect ect...i called him and he said that the leak isnt that bad which i am kind exaggerating on the leak...since i have bought it i havent had to put oil yet which it has been 4 days...its still on full......i called him anyway and he said take it to the mechanic on the receipts he has always looked after this car....i gave the mechanic a call and he said the same thing its the crank seal and he quoted to fix that 9 months ago and the owner never came back......its only $100-$150 to fix....the owner was tight on his money i guess....its just dripping bit by bit...but not effecting it too much just makes my driveway messy....
yea i am going to get him to change it.....i notice it only really leaks while the car is running....and right when i turn it off besides that after its settled it hardly leaks....so most definatly its the crank seal....
now instead of having major oil leak issues...my car has the usual second hand minor oil leak here and there.....i will fix those when i get the time...they are not pissing out...the mechanic told me the car is still in very good nic considering it has 240.000kms on the clock....he said it could use a nice oil and tranny flush.....he said to just fix the smaller leaks later as they wont do much inbetween changes...as far as i am concerned i am a very happy person right now...i can start modding the little things that i been wanting to do....
03-12-2020 12:06 AM
ag90fox
09-09-2015 12:22 PM
