Gotta re-do my oil pan gasket
Old Jul 9, 2011 | 10:42 PM
ef9's Avatar
ef9
I used Permatex Sensor-Safe Blue RTV Silicone Gasket Maker for the upper and lower oil pan.
http://www.permatex.com/products/Aut...sket_Maker.htm
I cleaned the surfaces so well, you could literally eat off of them. Apparently this gasket is leaking only a month or so after re-assembly.
I checked the torque on the oil pan bolts, and they are all good. I don't want to over torque them.
I gotta drop both oil pans again and use a different gasket maker. Which one would you recommend?
Stan
Old Jul 10, 2011 | 12:59 AM
felorojas14's Avatar
Stan
OEM...I did mine a few months ago and I've had no problem..Goes for about $15
Old Jul 10, 2011 | 01:01 AM
ef9's Avatar
ef9
Do you happen to have the part number for that gasket maker from Nissan?
Thanks!
Old Jul 10, 2011 | 02:47 AM
Dark_man_x's Avatar
I believe the Nissan P/N is 1217H, but all you have to do is go to the dealer and ask for the liquid gasket.
Old Jul 10, 2011 | 08:04 AM
Yea thats the one.
Old Jul 10, 2011 | 01:29 PM
pmohr's Avatar
No more Maximas...
Why the blue? Don't think I've ever used that stuff. Ultra Grey or Ultra Black and call it good.
IME they're better than the OE Nissan stuff, costs less, and much less visible than a bead of bright orange.
Old Jul 10, 2011 | 02:14 PM
DIAMONDS98SE's Avatar
I just got back from having my oil changed, and the guy said he saw a slight build up around the oil pan gasket. After doing some reading on here, I guess it may be the oil sending unit?...but who knows. I check the oil somewhat regularly, and the guy said it was full when I brought it in, and that was a few thousand miles late too...I guess Ill just keep an eye on it and see if it gets worse. Any suggestions would be appreciated.
Old Jul 10, 2011 | 09:09 PM
Snypa's Avatar
grey all dey !
Old Jul 10, 2011 | 10:32 PM
ef9's Avatar
ef9
I used the blue stuff because it says it can be used for oil pans, etc.
Old Jul 10, 2011 | 10:45 PM
max ride 41's Avatar
they use a thicker compound agent in the black, the gray is ok but i'd stick with the higher heat/oil resisant black rtv.
Old Jul 10, 2011 | 11:34 PM
ef9's Avatar
ef9
Thanks!!!!
Old Jul 11, 2011 | 08:39 AM
The OE Nissan stuff is ultra gray or dark gray.
Old Jul 11, 2011 | 09:09 AM
Snypa's Avatar
do you use the black for your valve covers as well!?
Old Jul 11, 2011 | 03:50 PM
pmohr's Avatar
No more Maximas...
Ultra Grey is a specific type of Permatex brand RTV.
The only Nissan RTV I've seen is the bright orange.
Old Jul 12, 2011 | 01:13 AM
Here is the picture of the OEM Nissan stuff I used. Its a ultra/dark gray and It worked great.
http://s977.photobucket.com/albums/a...quid%20Gasket/
Old Jul 12, 2011 | 02:50 AM
yep
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
knight_yyz
Nov 1, 2015 01:34 PM
