4.5 Gen Header Install
Old Aug 14, 2011 | 06:06 PM
nselca2's Avatar
I was contemplating on installing a set of obx v2 headers in my 4.5 gen maxima. But before I go ahead and dive head first into this, I want to get an idea of what exactly will be necessary for these to fit. Will I have to grind the crossmember as necessary in the 5th gen maximas? Also, how exactly do the 02 simulators get wired in? Any other necessary info would be great as well.
Old Aug 14, 2011 | 06:31 PM
QT1 5MT AE's Avatar
Gram Lights addict
please search. this has been discussed before.
Who started this "4.5" gen trend? all 4ths have VQ30DE, there is no reason to call 97-99's "4.5". 5th gen's do it because the chassis comes with two motor options.
Old Aug 14, 2011 | 07:12 PM
nselca2's Avatar
The reason for the 4.5 gen title would be because its a 3.5 swapped 4th gen. I do not see a thread on the forum with directions on a header install for 3.5 swapped 4th gen maximas, hence the reason for the thread. Wasn't sure if the header install would follow the same procedure as a header install for a vq30de maxima.
Old Aug 14, 2011 | 08:35 PM
Kevlo911's Avatar
Kevlo for President
It is exactly the same procedure.
Old Aug 14, 2011 | 08:44 PM
nselca2's Avatar
Thank you sir. And lastly, the 3.5 headers for the 02-03 max's will fit fine right? I thought I read somewhere that this was the case but just want to confirm.
Old Aug 15, 2011 | 01:20 AM
schmellyfart's Avatar
That is correct.
Old Aug 15, 2011 | 02:25 AM
maxspeed96CT's Avatar
The original VQ...
Theres a few threads kickin on here, but its not set in stone on what you have to do. Some guys have no issues with the obx fitment .
I had to notch about 3/8 off the crossmember cause it was hitting the flex, also had to trim the front motor mount bracket because it was hitting the collector.
G/Luck .
Old Aug 15, 2011 | 06:56 AM
nselca2's Avatar
Thanks for all the help guys.
Old Aug 15, 2011 | 07:29 AM
aackshun's Avatar
See link in sig to my blog.
Old Aug 16, 2011 | 01:37 PM
pgmax518's Avatar
What type of power increase do you get with this?
Old Aug 17, 2011 | 09:57 AM
nselca2's Avatar
Quick question. Since I need to pass emissions I need to install a fully functioning egr since Im getting an egr temp. sensor code. Even though the sensor has been hooked up, the cel will not go away even when clearing the code which makes me believe I need the complete egr system installed. My question is, as far as obx headers goes, are the 95-01 the only headers that have the egr bung? I heard that the 02-03 obx headers flow better and provide better gains so Id prefer to go with those headers. Any chance an egr bung could just be welded on or is that not possible?
Old Aug 17, 2011 | 09:58 AM
nselca2's Avatar
Gains should be somewhere around 15-20whp. Thats with the header and y-pipe.
Old Aug 17, 2011 | 10:14 AM
That's weird, I've never gotten a temp sensor code with my temp sensor dangling in the engine bay.
Yes, the 3L version has an egr bung, but the y pipe is not equal length. I've have also read about the rear header/y pipe not lining up to the front header without some modification.
Yes, you can have an egr bung welded onto the 3.5L version.
Old Aug 17, 2011 | 11:57 AM
ProW649's Avatar
Originally Posted by QT1 5MT AE
....Who started this "4.5" gen trend? all 4ths have VQ30DE, there is no reason to call 97-99's "4.5". 5th gen's do it because the chassis comes with two motor options.
lol
Noob - 1 Veteran - 0.
just for laughs
Old Aug 17, 2011 | 12:20 PM
nselca2's Avatar
Thanks for clarifying. 3.5L version it is
Old Aug 17, 2011 | 12:26 PM
nselca2's Avatar
Originally Posted by ProW649
lol
just for laughs
Old Aug 17, 2011 | 12:34 PM
NmexMAX's Avatar
dot dot dot ...
lol
just for laughs
Then why is the 07-08 A34 (6th gen) referred to as the 6.5 gen?
Old Aug 22, 2011 | 11:30 PM
ProW649's Avatar
I've never heard of this, beats me, but im guessin it has something to do with body styling, seeing as they have the same motor platform. and thts just a guess people
Old Aug 23, 2011 | 12:24 AM
mightyMax95's Avatar
aesthetic update. different front bumper mainly.
Old Aug 23, 2011 | 12:28 AM
aackshun's Avatar
This is a header thread, must mention the oil pan difference!
The dropping of transmission options, only CVT avail, different rims, minor updates to miscellaneous things... enough for a generational change, because the aesthetics are completely different and are a precursor for the current nissan vehicles... but man we're way off topic now...
Old Aug 23, 2011 | 12:36 AM
yeah, that's what i meant...
VQ'ed
69
Aug 27, 2020 12:29 PM
Finkle
Sep 27, 2015 09:53 PM
ac max 92
Sep 2, 2015 04:23 PM
stromm
Aug 27, 2015 04:13 PM
VQ'ed
Aug 19, 2015 04:52 PM
