Car Overheating
Old Aug 17, 2011 | 06:10 PM
mnml10387's Avatar
Car Overheating
I know there are tons of threads on this, but i can not find an answer to my problem in any of them.
I just recently replaced the radiator fans because they were shot. I thought this was the cause of my overheating issues, but my car is still overheating. The top hose is always very hot and the bottom radiator hose is cold.
Anyone have any experience with this. Thanks in advance.
Old Aug 17, 2011 | 06:24 PM
Daniel1120's Avatar
First check your coolant level. If the upper hose is hot while the lower hose is cold then your radiator is clogged.
Old Aug 17, 2011 | 07:10 PM
asand1's Avatar
You are not flowing coolant. Back flush radiator and replace thermostat.
Old Aug 17, 2011 | 07:57 PM
Trini Boom's Avatar
Replace your thermostat. It is not opening to allow flow. Also, verify that your fans are indeed turning on. Don't understand how the car overheats unless the collant level is low. Bought mine with a closed thermostat but didn't overheat. I only noticed because I was not getting strong heat.
Old Aug 17, 2011 | 09:10 PM
mnml10387's Avatar
The fans are definitely turning on, I always check. Also the coolant level is fine. It is very hot in Miami right now so after about 30 minutes of driving it overheats and i have to turn on the heater, it blows extremely hot air.
Can the Thermostat give you the right temperatures and still malfunction by not opening?
Old Aug 18, 2011 | 07:00 AM
bobflood's Avatar
+1 for this. Also, where are you checking coolant level? I had an issue with a cracked coolant overflow nipple - when coolant got hot it "overflowed" out the crack. The coolant level in the tank always looked OK, but the radiator kept loosing coolant. Eventually, car started to overheat and when I checked it out the radiator was nearly dry! New radiator and everything was fine.
Old Aug 18, 2011 | 07:32 AM
Kham's Avatar
You can take out thermostat to see if coolant flow, Or you can just replace it.
Old Aug 18, 2011 | 08:16 AM
DennisMik's Avatar
Check and see if the space between the radiator and the a/c condenser coil is clear and not full of junk.
Check coolant level by removing radiator cap when the engine is cold. The coolant should be completely filling the radiator - no air. If the radiator is full, I would suspect that the thermostat is not opening up like it should.
Old Aug 18, 2011 | 09:48 AM
mnml10387's Avatar
It's definitely full from the radiator. Ill check the thermostat today.
Old Aug 19, 2011 | 02:30 PM
mnml10387's Avatar
I took out the thermostat today and I put in 180 degree water and it did not open up. It seems it was letting a little bit of water go through, but it definitely did not open up. I'll go buy another one and see how it goes.
Old Aug 19, 2011 | 07:17 PM
Trini Boom's Avatar
OEM I paid $25. You should seek out one.
Old Aug 19, 2011 | 07:44 PM
seedless619's Avatar
sucks
Old Aug 20, 2011 | 12:25 AM
mnml10387's Avatar
Ya i bought one today at Autozone and i paid 30 with the seal. I tested it and it opened just like it was supposed to. I'm going to install it tomorrow.
Old Aug 22, 2011 | 12:56 AM
mnml10387's Avatar
I replaced the thermostat today and the car did not overheat with the a/c on blast. I'm so glad to have this problem fixed. Thanks for the input.
Old Aug 22, 2011 | 06:07 PM
Trini Boom's Avatar
Old Aug 22, 2011 | 06:45 PM
Haishun Boi Max's Avatar
Old Aug 22, 2011 | 09:03 PM
DennisMik's Avatar
I love happy endings!
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Gsantos79
Aug 8, 2015 07:41 AM
