Bogging and Stalling PO100
Old Oct 10, 2011 | 11:32 AM
J2songz's Avatar
For a few days my car has be stalling out and I didn't know the cause of it, lucky I keep my scanner on me because going 80mph and stalling out is not to fun with cars behind you.
So once it stalls its hard to get is started or if it did start it will stall again so I had to keep reseting the ECU to get the car home. I figured the issue was a broking MAFS because I broke something on it awhile back. After checking everything out I decided to replace the filter which was dirty, cleaned the MAFS and cleaned the TB. I had some oily like crap in my intake tube. I put it all back together and started right up, also had some power gain returned and better TB response, it hasn't stalled so far.
But I do need to replace my MAFS soon
Hope this helps some1 with the same issue
Old Oct 11, 2011 | 03:59 PM
clive's Avatar
100% chingon
Stalling at 80 mph is not likely to be the MAF. Just possibly, if the MAF plug/socket connector is going intermittent, but no, more likely a crank position sensor, that's a prime cause of suddenly conking out. Same problem on Altimas. Replace both.
Old Oct 12, 2011 | 08:27 AM
J2songz's Avatar
I scanned it for the code and it was just the P0100, my intake wasnt getting the proper air flow. It had the same affect as if 1 of my vac lines was being clogged but i fixed it and its running strong now with no issues
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
97_GXE
Sep 15, 2015 06:47 AM
