HELP!! PLZ Nostart no crank no nothing
Old Oct 12, 2011 | 08:50 AM
blackmaxftw's Avatar
I know so much about Maximas and i thought i would never have to post on here again but i did a dek swap and i drop the motor and transout at the same time and left the starter and everything attached i put it str8 into a 4thgen and hooked everything up .i get in turn the key and absolutely nothing happens when i turn the key to start it, everything else works fine all acc .any ideas ??? oh its a 5thgen trans and starter ive used a 5thgen trans before and did the wiring so i nothats not it and i swithed the pnp switch over from the 4thgen trans..........will a 5thgen starter work on a 4thgen engine harness????
Old Oct 12, 2011 | 09:11 PM
99superblackmax's Avatar
That's a good question about the starter, not sure on that. Do the interior lights, illumination, etc. shut off when you try to start it? May have a loose ground somewhere. Is the security light on?
Old Oct 12, 2011 | 09:13 PM
Didn't see starter on 4th gen harness. That is more than likely your problem. Could have different power and ground connections in the pigtail
Old Oct 12, 2011 | 10:05 PM
DennisMik's Avatar
The electrical hookup to the starter is the same for 4th gen and 5th gen. Thick cable from the battery and thin wire from the ignition switch. The 4th gen uses 2 relays to get the power from the ignition switch to the starter solenoid (thin wire.) The 5.5 gen uses 1 relay. I don't know if the plastic connector is the same for the solenoid wire.
Old Oct 13, 2011 | 10:20 AM
So what should i check I checked the starter sig fuse and wheres the ign relay..........Oh and 1 more thing when i put the key to the on position and go under the hood and disconnect the negative battery cable usually i hear the relays click as i touch the cable to the neg post on batt when when i do this i hear absolutely nothing..........I tried this in my moms 4thgen and all relays and stuff under the hood clicked the egi relay click along with alot of other ones.....and her car start right up.
Old Oct 13, 2011 | 11:59 AM
cardana24's Avatar
Blown
bad starter
ignition switch
bad battery
poor engine ground
corrosion on the battery terminals
fuse
is the car in park when you try to start it? Neutral safety switch?
I don't know the answer about the 5th gen starter, but I am guessing a multimeter would answer that question.
Old Oct 13, 2011 | 02:04 PM
I got the starter tested and it worked,didnt try the ignition switch yet and never had a problem with it ,i clean the engine ground,and brand new batt only 2 months old.......i switched the pnp switch twice and and i think the starter will work i put a 4th gen starter on and i dont even get a click from that either
Old Oct 13, 2011 | 02:13 PM
luke95gxe's Avatar
its prolly a relay or fuse what u can do is turn the key to on and jump the starter with a jump wire from the battery to the trigger wire on the starter there are 2 relays beside the fuse box under the dash did u check them?
Old Oct 13, 2011 | 02:53 PM
Trini Boom's Avatar
I am pretty ceetain that the 00 - 01 starter should be a direct fit. As for the 02 - 03, that's where I think its different. Which one are you using?
Old Oct 13, 2011 | 03:39 PM
the 01
Old Oct 13, 2011 | 08:23 PM
After all you have tried I would consider the ignition switch next. If swapping the 4th gen starter didn't help, it seems there's something happening between the ignition and starter
Old Oct 14, 2011 | 01:28 PM
Still No nothing!!!
Old Oct 14, 2011 | 01:56 PM
cardana24's Avatar
Blown
will the car start by manually bypassing the starter signal (grounding the starter)? I am not really suggesting you do this for safety reasons, but I have done this before to make cars start if the key will not turn the starter over.
*Disclaimer*
^^This will not fix your problem but if you have to have the car started it may get you out of a bind.
*also, have you tried charging you battery? I know you said it is new, but it would not hurt to make sure it has a full charge.*
Old Oct 14, 2011 | 03:43 PM
Yes i just finished doing this its like its not getting any ign signals from anywhere no gas or anything my fuel pump doesnt even prime ussually it buzzes but nothing i just checked that
Old Oct 14, 2011 | 06:53 PM
DennisMik's Avatar
Did you check the fuses under the hood? There is one labeled IGN SW that feeds the ignition switch. The ignition switch then feeds a lot of other things and the fuel pump and starter are among them.
TKHanson
Nov 24, 2018 01:39 AM
chisam14
Nov 6, 2018 08:56 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
conansriver
Sep 11, 2015 10:26 AM
