bad starter or something else?
Old Oct 24, 2011 | 05:24 PM
nba0203's Avatar
so on saturday i was driving and i started to hear a weird loud noise coming from the engine bay so i pull over in a parking lot to check it out. i turn off the car to check under the hood and i noticed smoke coming from the starter and a burning smell. i tried starting the car again after it went away but it did not even turn over. i checked everything else electrical so i do know that the battery is fine. i just replaced the starter in april so i am wondering if the no starting problem is due to a bad starter or could it be something else
Old Oct 24, 2011 | 05:51 PM
DennisMik's Avatar
The answer is always a maybe. The only time the starter does anything is when you turn the key to start the engine. When the car is parked or the engine is running, the starter is just sitting there nothing, same as if it was in the box. But if the starter did not retract its pinion gear from the flywheel once the engine started, the engine would spin the starter so much faster than it was designed to handle.
The only way to tell is to take the starter out and have it tested. If you got it in April, it may be under a warranty. Most places give you a year warranty.
Old Oct 25, 2011 | 09:58 AM
skim35's Avatar
Sounds like your starter burned out. Did engine sound normal? Or something was grinding?
Old Oct 25, 2011 | 10:02 AM
AllMaxxedOut's Avatar
Definitely sounds like starter. Did you install yourself or did someone else?
Either way, make sure it is grounded off.
Old Oct 26, 2011 | 07:08 AM
slfalco's Avatar
Sounds like the starter gear got caught up with the flywheel and got spun so fast it probably ruined it. Sometimes aftermarket starters don't fit exactly right, and need to be shimmed at the mounting surface.
chisam14
Nov 6, 2018 08:56 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
RealityCheck
Oct 2, 2015 06:34 PM
maxima297
Sep 30, 2015 03:32 PM
Andy29
Sep 29, 2015 05:32 AM
