Possible Lean Condition ? PLZ Help
Old Oct 30, 2011 | 10:20 AM
Steve31's Avatar
So it's getting colder here 30's & 40's
I went to pass someone and once I hit around 4k the engine
started to cut out and pop back (like a lean pop) I have had a feeling my injectors where on there way out for some time so I test the ohm's on all of them according to this thread
http://forums.maxima.org/4th-generat...esistance.html
On pin's 1&2 I have 13ohms
On pin's 1&5 I have 11.3 ohms
On pin's 1&6 I have 10.3
Then on cyl 2 is 10.6 cyl 4 is 12.9 cyl 6 is 10.3
Which ones are bad or are they all bad ?
Went to the salvage yard and bought a whole nother rail and injectors
ohm'd those and they all have 10.6 (all 6) Should I install all these ?
Old Nov 1, 2011 | 09:09 PM
Steve31's Avatar
Any advice ?
Old Nov 2, 2011 | 07:48 AM
njmaxseltd's Avatar
A misfire under load is usually a sign of failing coil packs/weak spark.
Our injectors are not prone to failure, our coil packs are.
Old Nov 2, 2011 | 08:05 AM
pflicht's Avatar
Pop off the uim and install the "new" rail with the injectors
Old Nov 2, 2011 | 08:25 AM
Steve31's Avatar
I have replaced 2 of the injectors last year due from 0 ohm's (Just dead)
Prolly will install the other set this weekend considering they where only $20
for the set lol
Is there a sure way to test the coil packs ?
I have a friend with a 99 that is having a similar problem
Old Nov 2, 2011 | 10:26 AM
wirelessdude04's Avatar
you can try it. But usually under load your coilpacks will go. Did you try tesing the coils?
Old Nov 4, 2011 | 05:08 AM
Steve31's Avatar
How do you test the coil packs ?
jmlee44
Oct 2, 2022 02:13 PM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
fx4five
Oct 18, 2015 06:57 PM
