Very unusual misfiring
I'm getting used to the idea that my Maxima will be misfiring more of the time than it will be firing on all cylinders, but I'd still like to get it running smooth...I've replaced a few coils over the last year, but both times they went bad it was a steady misfiring, running very rough. So the first coil I replaced was OEM, the second duralast. Duralast threw a code so I swapped it out for a junk yard oem for $8. Now a few weeks later, I am misfiring again but now its totally random, usually starts at idle or when accelerating uphill or low rpms. If I'm stopped and i put it in neutral, it stops. Should I just start by replacing that coil again? I think i'm going to buy a multimeter today and check all the resistances. Thanks in advance for suggestions.
Yea, check resistance you can also chek by disconnecting each coil as the car is running. When was the last time you changed your plugs? Make sure there are no vacuum leaks either maybe a hose came loose or fell off.
Oh any check engine light?
jmlee44
10-02-2022 02:13 PM
ballerchris510
09-11-2015 05:29 PM
