Hating my maxima right now
Old Dec 30, 2011 | 08:22 AM
cjones450's Avatar
Ok so I have had this problem for a while now about a month ago my car broke down gas was shooting from the exhaust so i changed all of the injector orings. Three days later the same issue happened and found one of the orings had a very small nick in it. So the car drove fine for a day and now today its back to doing it again i replaced all of the lower injector orings with factory nissan rings. Any reason why this keeps happened it has left me stranded going on 3 times now for the same issue.
Old Dec 30, 2011 | 08:37 AM
Wait and see if it happens again. I don't understand why it keep happening unless it's installation error.
Old Dec 30, 2011 | 08:39 AM
cjones450's Avatar
well it has happened again thats the issue i pulled all the injectors out and the orings are fine no slits or nicks or anything and my other issue is iv bought every single injector oring from my local nissan dealers and have successfully sold out 4 different dealers and i only have a total of 6 orings now
Old Dec 30, 2011 | 09:02 AM
hornepirate's Avatar
My money is on your fuel pressure regulator.
that would seem to be the only reason you keep going through o rings. when mine went i had the same symptoms but i changed the FPR immediately its only about $70 and easy to install
Old Dec 30, 2011 | 10:01 AM
RyanJerome07's Avatar
Check your hose connections, and make sure your fuel injectors aren't dirty or need replacing. One or more could be sticking open and causing the fuel leak.
Old Dec 30, 2011 | 10:05 AM
cjones450's Avatar
i will try that first but why all of the sudden before it was the oring and then all of the sudden an injector?
Old Jan 1, 2012 | 11:49 AM
cjones450's Avatar
Turns out two of the plastic injector tips were missing so bought two new injectors and problem fixed
JRod28
Feb 4, 2016 11:07 AM
Balkins
Aug 12, 2015 06:39 AM
MikesChevelle
Aug 7, 2015 05:57 PM
MikesChevelle
Aug 6, 2015 11:36 AM
