What do you do when your Y-pipe gaskets won't seal correctly?
Old Jan 8, 2012 | 12:48 PM
shadyonedeath's Avatar
I think my y pipe flanges (the groves for the crush gaskets) is un-even/warped because I cannot get this y-pipe to seal correctly for more than 3 days. I've gone through 5 sets of gaskets....FIVE, thats TEN crush rings!! And i get the same results no matter how tight (or not) I bolt it down. I turn each bolt little by little and it always ends up leaking. Pissing me off. Everyday it performs a different day depending if my chasis is twisted or not by roads/bumps/ hills.
Note: Exhaust manifold was so rusted some of the studs came out/snapped...so i had to use bolts and tap new threads in one of them (bigger) so I could see all 3 sides of each flange. So in front i have, 2 working studs and 1 substitute bolt, in the rear i have zero studs, but three bolts. They dont even come lose, its the gasket inside, how it's crushed thats un-even.
And i dont think i can upgrade to headers because I'm not confident the header bolts will come off easily...without complications. Like I said, the rust is bad.
Old Jan 8, 2012 | 12:56 PM
GGENIUS's Avatar
hmm lots to read, especailly with my short attention span. but why dont you try getting new studs put in?
Old Jan 8, 2012 | 01:46 PM
Try some of this under and on top of the crush gasket:
http://www.permatex.com/products/aut...one_Gasket.htm
Old Jan 8, 2012 | 02:08 PM
CMax03's Avatar
Motor mounts must be worn!
Old Jan 8, 2012 | 02:14 PM
CMax03's Avatar
Or measure your collector size and place a copper 3-bolt gasket in place of that POS seal! There's something you're missing...causing your premature rejectulation of seals...
That stuff killed all my o2 sensors....I even bought the High temp copper sensor safe type. Im about to punch somebody @ permatex
where can i get that gasket? And what in the world is rejectulation?
Old Jan 8, 2012 | 02:30 PM
CMax03's Avatar
Summit (SCE) what size is the Ypipe secondary tubing? Rejectulation is just some of my sarcasm....like premature ejeculation.....
Old Jan 8, 2012 | 04:12 PM
Trini Boom's Avatar
Is this an OEM y-pipe or aftermarket? I dont see how all these flanges could possibly keep going out.
Old Jan 8, 2012 | 04:35 PM
CMax03's Avatar
Might be time to spend some money on some eBay headers and cure your problem!
Old Jan 8, 2012 | 04:41 PM
Rods03Max619's Avatar
Any pictures and is this a aftermarket Y -pipe or the stock one.....
Old Jan 8, 2012 | 06:23 PM
warpspeed
Old Jan 9, 2012 | 11:23 PM
nitromax's Avatar
are the flanges flat? if overtightened the flanges can bend into contact with each other & not allow the gasket to seat & seal. if that's the case bend them away from each other.
Old Jan 10, 2012 | 01:23 AM
Madmax1999's Avatar
Whens the Cattman going to have more in production?
would like a set of those headers, y-pipe, cad converter and catback!
Old Jan 10, 2012 | 06:45 AM
CMax03's Avatar
This guy is selling some used Cattman Headers:http://forums.maxima.org/4th-generat...her-parts.html
Old Jan 10, 2012 | 06:49 AM
CMax03's Avatar
warpspeed
If you're having problems with a badly rusted exhaust manifold(s) go the junk yard route and pull some decent used cast iron exhaust manifolds or buy some aftermarket tubular Headers......
Quickywd01
Sep 21, 2016 09:36 PM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
leatherneck
Sep 30, 2015 09:16 PM
