Mantual Trunk Release Question
Old Jan 16, 2012 | 07:33 PM
Infowire's Avatar
Manual Trunk Release Question
My max has a handle i pull on the ground to open the trunk. I got a viper 5904 remote start/alarm and i wonder if i can make it pop my trunk somehow
Old Jan 16, 2012 | 07:40 PM
mrjasonlyrics's Avatar
I think you mean "manual" trunk release
Old Jan 16, 2012 | 07:41 PM
Maxima_Joe's Avatar
4th Gen Parts King
Yes you would have to disconnect that linkage and install the power actuator in the trunk. It's pre-wired so you would just have to tap into the wiring for your alarm. If your interested in buying the actuator PM me.
Old Jan 16, 2012 | 07:50 PM
Infowire's Avatar
wonder if i can keep my manual trunk release and install the actuator to use with the alarm.
Where is the actuator located normally?
Old Jan 16, 2012 | 08:05 PM
Maxima_Joe's Avatar
4th Gen Parts King
I don't see why you would want to keep the manual release but you could fab something up. Would just be easier to add the trunk switch to the drivers door panel which is also prewired.
Actuator is to the left of the trunk latch.
I don't have any pics of it installed but here's one of the actuator.
Old Jan 16, 2012 | 08:19 PM
Infowire's Avatar
i am going to go to the junk yard to pull one out, i am getting my alarm installed wed so i need one by then. So now i need a door panel with a button.
Reason i would like to keep my manual one... simple
If battery is dead on the car... i can open trunk and i wouldn't need a new door panel
Old Jan 16, 2012 | 08:25 PM
Maxima_Joe's Avatar
4th Gen Parts King
For the switch you just cut your door panel. Doesn't your key work in your trunk lock? The only reason I see you needing in the trunk would be for jumper cables. Couldn't you grab those from the back seat pass-thru.
Old Jan 16, 2012 | 09:16 PM
Infowire's Avatar
my key doesn't work for the trunk, and my passage is blocked off with sub woofer
Old Jan 17, 2012 | 02:00 AM
infinimax96's Avatar
Keep jumper cables between the pass through and subwoofer and delete the manual latch.
*swish* Problem solved.
Old Jan 17, 2012 | 04:47 AM
The trunk will have to be disabled for the actuator to work with the aftermarket alarm, but you can install a hidden switch that could work with the aftermarket trunk release. You just have to add a relay. But any professional alarm installer should be able to do that.
Old Jan 17, 2012 | 07:37 AM
benjie's Avatar
So, just to clarify, the SE came with the actuator instead of the manual release?
Old Jan 17, 2012 | 09:04 AM
Infowire's Avatar
on my old max didn't have to disable anything, the actuator with the button worked and my key fob worked, just had to add a relay.
Old Jan 17, 2012 | 09:37 AM
DennisMik's Avatar
I find this thread interesting.
In the op's original post, he puts in "Expert in Installing: car alarms, car audio, car bombs, remote starts."
Hmmmm
Old Jan 17, 2012 | 02:21 PM
Infowire's Avatar
well i can install the alarm, just wondering what i could do about the manual trunk release, i was hoping for some ideas how to keep my manual trunk release.
Old Jan 19, 2012 | 04:00 PM
luke95gxe's Avatar
http://forums.maxima.org/4th-generat...-few-pics.html
heres my write up
Old Jan 19, 2012 | 06:04 PM
the_nite_owl's Avatar
It may be possible to have both cables connected in the trunk and not have to disconnect the original in order to have the remote pop.
I have not seen how these cars are setup so cannot be specific but the idea is to find a way to connect both cables to the same point or if there is enough exposed cable for the manual pull to clamp down directly on that so when the actuator pulls it will tug the original cable releasing the latch.
There are a lot of possibilities but may require some custom modifications to make it work but this is exactly what I would be trying for myself. Seems wrong to have a manual release lever and not have it working. Unless of course you put it to other purposes.
Junebug1701
Sep 25, 2015 01:54 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
