Water Pump/ Timing Chain Cover Removal PITA **pics**
Old Jan 24, 2012 | 09:30 PM
mpvibes's Avatar
So, I decided to go ahead and do the dreaded water pump replacement job on my EDIT: 263,000 mile 4th gen. What a PITA! I had to do it the looong way because #1 I had a leak on my timing chain cover and # 2 I wanted to make sure my timing was accurate and my car didn't jump timing, bend any valves etc. Well, since it was my first time ever doing this job, it took me 2 days and I did learn alot. Man, my oil pan and all my timing chain components were covered in oil sludge, it was ugly I had to do alot of cleaning, using gasoline! Well, here are some pics that I wanted to share with you all. Sorry for some of the crappy pics....
UPDATE: When cleaning and putting on the lower oil pan just get a NEW Felpro oil pan gasket and follow the tightening sequence! Don not put RTV silicone on there. I had a leak and had to get a Felpro gasket.
New Nissan Water Pump
Oil sludge all over timing components
Broke the old water pump while taking it out
Cleaned and looking good!
Old Thermostat and New Thermostat side by side
Old Jan 24, 2012 | 10:13 PM
Amerikaner83's Avatar
so is this the first time the WP has been replaced? If so, damn that's good life-span of that thing!
Old Jan 24, 2012 | 10:30 PM
2brosgixxer's Avatar
Looks like you need some power steering fluid too
Old Jan 24, 2012 | 10:34 PM
BigLou55's Avatar
you have ***** my friend...I don't think I would every ATTEMPT this job.
Old Jan 25, 2012 | 01:04 AM
schmellyfart's Avatar
Wow good stuff man.
Old Jan 25, 2012 | 02:50 AM
CMax03's Avatar
You obviously took that all apart too clean the sludge! Cause changing the W/P can be done by removing the 2 access panels on the timing cover.....1 for the tensioner.....1 for the W/P! I'm doing mine too, but no need too take all that apart unless you're gonna change the timing chain, sprockets, guides, and tensioner etc.....
Old Jan 25, 2012 | 04:03 AM
infinimax96's Avatar
Nice job! I need to do the Timing Tensioner soon on mine. I'm at 255k miles, I'm wondering if I should consider changing my pump while I'm at it. My car doesn't have any issues over heating though, so not sure if the pump needs to be replaced.
Old Jan 25, 2012 | 04:07 AM
phatboislim's Avatar
^this
i sent mine straight to the mechanic like *** that, ill pay the man
Old Jan 25, 2012 | 04:08 AM
if you read, he said his timing chain cover was leaking as well, however it was, it was leaking. and he said it was his first time, its not like this sort of information of how-to replace the water pump is easily accessible on this site either, in fact i cant remember a thread in the 4-6th gen sub forums where there's a how-to thread on doing the water pump
Old Jan 25, 2012 | 05:24 AM
cjandura's Avatar
+1 the only thread i think i seen was the one where it said you have to pull the engine to do it.
Old Jan 25, 2012 | 06:04 AM
Water pump replacement is in the 4th gen how to sticky. http://forums.maxima.org/4th-generat...teup-pics.html
See, the 4th gen section isn't completely worthless
Old Jan 25, 2012 | 09:21 AM
i've been told LOL!!!!!! i'd still take it to the mechanice cuz i'd be the one the timing would jump on #fukthat
Old Jan 25, 2012 | 04:12 PM
mpvibes's Avatar
Yes, sir it is. This water pump lasted me around 265,000 miles and could still go some more.
Old Jan 25, 2012 | 04:16 PM
mpvibes's Avatar
Yeah, thx for reminding me
Old Jan 25, 2012 | 04:18 PM
mpvibes's Avatar
Yeah, this was not an easy task at all. It was a PITA! It was almost as much work as doing my 5 speed swap, because everything is in a tight space!
Old Jan 25, 2012 | 04:23 PM
mpvibes's Avatar
My timing covers were leaking oil all over. There was sludge all over my oil filter and everywhere else. I thought the same thing too. You can take the water pump off through the access covers but, if you jump timing and don't have timing set right you can mash up your engine. It was the long way but, it was the right way for a complete job.
Old Jan 25, 2012 | 06:24 PM
Trini Boom's Avatar
Its not that bad of a job once you done it successfully. Hope you changed the tensioner and guide if you haven't done so already.
Old Jan 26, 2012 | 04:30 AM
CMax03's Avatar
Maybe there wasn't a How too thread B4 this! But there was already a reference too use well B4 the internet was available.....FSM....Doing the W/P replacement thru the access panel isn't going to cause you to jump timing....once you remove the tensioner, you move the crank pulley counter-clockwise approximately 20 degrees to remove the timing chain off the w/p sprocket....Installation is reverse.....
Old Jan 26, 2012 | 07:21 PM
SethGreen's Avatar
man that looks like a ton of work im dreading to my water pump replacement =(
Old Jan 27, 2012 | 05:21 PM
mpvibes's Avatar
I understand what your saying, I saw the directions to do it that way but, its better to be safe than sorry.
Old Jan 27, 2012 | 07:24 PM
RA030726's Avatar
I'm nutty for Nissans
Curse you for using hi temp red RTV. The correct stuff is grey which blends in.
And yes you should have replaced all of your guides and tensioners, but don't worry I wont tell anyone if you didn't.
Old Jan 27, 2012 | 09:35 PM
EmergesUnscathed's Avatar
Ugh. I was thinking about changing the water pump when I have time, because they seem to go at the most inconvenient moment. Looks like I'll just cross my fingers.
Old Jan 28, 2012 | 11:26 AM
mpvibes's Avatar
LOL! Yeah, when I do my VQ35 swap I will be getting a full timing kit.
Old Feb 10, 2012 | 09:48 PM
drakkan's Avatar
Is there a write-up or tutorial somewhere with pics/video on how to remove the timing chain cover?
Old Feb 11, 2012 | 12:15 AM
nsnrider's Avatar
looks like someone didn't keep up with the oil changes.
next step, pull the valve covers and clean up the sludge of the valve train.
good job on the large job. I've done this before and will not do it again without dropping the motor. I can drop the engine and reinstall it in a day, and is easier than doing this in such tight space.
Old Feb 23, 2012 | 07:58 AM
mpvibes's Avatar
To tell you the truth I'm not sure but, that timing cover has so many damn bolts that r hidden it's not even funny.
Old Feb 23, 2012 | 08:00 AM
mpvibes's Avatar
Dang in a day?? That's real good bro. Yes, it was a PITA to work on in a tight space with the motor in the car.
Old Feb 23, 2012 | 12:25 PM
Product_Of_Korea's Avatar
I can't remember if it the outer or inner tc cover that has a couple of bolts in the oil pan that peeps tend to forget about.
I give anyone props for doing this with the engine in the car. I struggled with it out of the car I couldn't imagine doing it still in the car. But then again I am a skinny asian lol
Old Feb 27, 2012 | 07:21 PM
mpvibes's Avatar
Yes, there r bolts that r attached to the timing cover located in the oil pan. I had to drop the oil pan. Thank you for the props!
Old Feb 28, 2012 | 03:11 AM
CMax03's Avatar
Why are you taking all that off? That's not necessary to change the w/p.....
Old Feb 28, 2012 | 02:45 PM
mpvibes's Avatar
Read my brotha read!
Old Oct 21, 2012 | 03:38 AM
floydthedog's Avatar
damn, looks like i'm in for a fun weekend...
Old Oct 29, 2013 | 05:21 PM
gruesome's Avatar
The first idiot I hired dropped the spring and cover for the tensioner in the cover. Hired a more competent guy and I'm helping.
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
