Car smoking and idk why....
Old Jan 28, 2012 | 05:20 AM
Shift_Nismo's Avatar
So my car recently began smoking on the upper passenger side of the engine and idk why. Any suggestions? The car also seems to bog on and off when driving.
Old Jan 28, 2012 | 06:56 AM
beatdown97's Avatar
Sounds like you have an oil leak at the passenger side front valve cover gasket which will leak oil onto your alt, and down the front side of the engine(hot engine+oil=smoke) the only reason i could think it would be bogging down is that maybe your dripping oil on the belt which will make it slip periodically
Old Jan 28, 2012 | 07:04 AM
Kevlo911's Avatar
Kevlo for President
take a pic of that side of the engine, it should be easy to spot where the oil is running(assuming that is the case)
Old Jan 28, 2012 | 07:13 AM
So it looks like the car decided to start leaking what looks like coolant and or water last night. So what could be the problem? Here are pics:
This is the area that the smoke was coming from:
And here is a video of it leaking:
http://s157.photobucket.com/albums/t...128_095555.mp4
Old Jan 28, 2012 | 07:26 AM
Kevlo911's Avatar
Kevlo for President
just from these pictures, i would say 2 bad valve cover gaskets, bad water bump, bad oil pressure switch
can you check your oil dip stick and see if it has any white bubbles on it?
Old Jan 28, 2012 | 07:27 AM
Kevlo911's Avatar
Kevlo for President
also i would tighten the hose clamps on the power steering reservoir and fill it up with some ATF
Old Jan 28, 2012 | 07:32 AM
The dip stick doesnt have any white bubbles in it. The water pump was replaced at 127k, how often do they go out? And roughly how much would it be to fix?
Edit: I just got a quote of $472 for the water pump job
Old Jan 28, 2012 | 07:41 AM
Kevlo911's Avatar
Kevlo for President
yikes thats alot for 1-2 hours of labor and a 80 dollar part, did you check all your hoses (in and out the rad)
on the left side of the engine(view from hood open), follow the rad hose where it meets the engine, is it leaking there? could be a leaking thermostat gasket
Old Jan 28, 2012 | 08:37 AM
Jus checked the rad hose, no its not leaking there. I guess ill shop around for some quotes. Thanks alot
Old Jan 28, 2012 | 08:39 AM
beatdown97's Avatar
And if its smoking from that corner that means its more than likely oil dripping down onto your pipe which will create white smoke, check your radiator hose very carefully, if its not a leak in your clamps then it sounds like your lower radiator hose has a pinhole in it
Old Jan 28, 2012 | 08:44 AM
Kevlo911's Avatar
Kevlo for President
yea it might only leak under pressure, and it could be the thermostat gasket. i am not 100% sure it is the water pump (i dont think they leak THAT bad)
Old Jan 28, 2012 | 09:08 AM
Yea it only seems to leak under pressure, the car has been off for a little while, and its not leaking anymore
Old Jan 28, 2012 | 09:10 AM
Kevlo911's Avatar
Kevlo for President
i would let the car warm up and try to find the source of the leak again
Old Jan 28, 2012 | 09:12 AM
beatdown97's Avatar
Start the car at a dry spot in the driveway and check for the leak and try to locate the actual leak, if the hose has a pinhole in it itll def leak with the car running its like when you fold a water hose to stop the water from coming out if theres a leak anywhere youll find it
Old Jan 28, 2012 | 09:44 AM
So I let the car warm up, and it seems to be leaking below where I drew the red circle, somewhere underneath the belt it looks like:
Old Jan 28, 2012 | 09:55 AM
sickwitit's Avatar
thats where mine is leaking from too right below there, i think it has something to do with power steering fluid since mine drops slowly weekly, maybe some nissan mechanics can help out here lol
Old Jan 28, 2012 | 10:53 AM
Gismo-T's Avatar
B!tch We Got a Problem
You may have a bad power steering pump or hose, also check your timing cover gaskets for leaks. But yea, the oil pressure sending unit could be the culprit, aswell as your lower oil pan. As for the watepump, check & see if anti-freeze is coming from the weephole.
Also, you should clean off all the oil with brake clean to determine where the leaks are coming from or do what I did is pour a small amount of uv additve in pwr steering pump, wait a few days & check with a uv light. Happend to be the pump, since all the hoses were dry.
Old Jan 28, 2012 | 02:17 PM
EmergesUnscathed's Avatar
What kind of smoke? What color? If it's blue and smells... engine like... it's likely engine oil or power steering fluid. If it's white and smells sweet/gross it's likely that coolant you're leaking burning off.
Old Jan 28, 2012 | 05:35 PM
Its white smoke, not really sure what it smells like though, I dont remember
Old Jan 29, 2012 | 08:17 AM
Kevlo911's Avatar
Kevlo for President
Isnt that the water pump cover?
Old Jan 29, 2012 | 09:09 AM
Yea I believe it is, and its leaking below there. And I checked the smell and it smells sweet.
Old Jan 29, 2012 | 11:25 AM
Kevlo911's Avatar
Kevlo for President
i guess you need another water pump, warranty left on the old one?
Old Jan 29, 2012 | 05:10 PM
Dan_E_Boi84's Avatar
Definitely a bad water pump... Most shops give a 1 year/12000 mile warranty depending on which comes first. At least they do at the Nissan Dealership I work at. If it's a Nissan part it has a 1 year/12000 mile warranty on the part regardless provided you can prove documentation of the purchase and repair.
Old Jan 29, 2012 | 05:52 PM
I highly doubt the warranty is left on the old one, and even if it is, I can't prove it b/c I dont have documentation of it, the repair was done while in the previous owner's possession.
Old Jan 29, 2012 | 06:05 PM
Kevlo911's Avatar
Kevlo for President
I would get the AISIN pump from here:
http://www.rockauto.com/catalog/x,ca...,parttype,2208
Old Jan 29, 2012 | 06:16 PM
max ride 41's Avatar
make sure you keep the rad fluid at the right level at all times, especially now that its cold out. make sure the overflow tank is on the line when cold and make sure its 50/50 antifreeze. too much water wont protect the heads and the block, i know somebody that just lost their max over similar issue.
clean off the block and see exactly where its leaking. you dont want to play guessing games with an old car and throw your money at it and fix the wrong things, pricey.
oil pressure switch, power steering pump line, gasket, or pump could all be leaking. thats why you should clean off the block first to be sure, good luck.
Old Jan 30, 2012 | 01:11 AM
CMax03's Avatar
Why a bad w/p? If it's leaking it's inside the timing cover mixing with his oil!!!!!!!
Old Jan 30, 2012 | 01:29 AM
CMax03's Avatar
Why the water pump???????????
Check the water pump weep hole?????Come on man this ain't no belt driven w/p....The w/p is behind the timing cover and if it were leaking it wouldn't be on the ground but in the oil pan with the oil!
Don't worrry about your w/p that not your problem! You need the clean your engine first of all (brake cleaner or the car wash), and determine where the leaks coming from! Do you have a bright flashlight and inspection mirror??? More than likely the smoke is your rear or front V/c covers leaking oil onto the exhaust manifolds directly below them! The coolant leak could be from a hose, radiator or the coolant tubes and coolant port just above the altenator...please look closely...GL Kid you'll need a jack and stands and to remove your splash shields.....clean it and run it for 30 min and you will find your origin of the leaks and smoke....watch your p/s hoses as well.....GL
Old Jan 30, 2012 | 02:57 PM
I<3 A32's's Avatar
so its antifreeze ?? if it is check the heater core hoses if no then check your power steering hoses the return line are very common to go out
Old Jan 30, 2012 | 03:13 PM
Kevlo911's Avatar
Kevlo for President
When the water pump goes bad, the coolant doesnt mix with the oil, it drips out of the hole at the bottom of the timing cover
Old Jan 30, 2012 | 05:14 PM
BigLou55's Avatar
yup when my water pump went bad on my 00 SE coolant leaked on the ground not in the oil AT ALL. Coolant would only mix with the oil if both o-rings(coolant side and oil side) have failed or if you have shaft play on the w/p
Old Jan 31, 2012 | 08:32 AM
UPDATE: So the car isnt leaking anymore, and it is warming up normally again...WTF? I dont get it lol. I havent seen any smoke so far. I drove it yesterday quickly and everything was fine, but I didnt go far so this morning I decided to let it warm up, and nothing came out. Any ideas? The car will b getting, whatever is wrong, fixed very soon, but I just want some opinions on what is going on.
Old Jan 31, 2012 | 09:44 AM
asand1's Avatar
I have to agree with CMAX03 on this one. The weep hole is BEHIND the REAR timing case half. A bad wp would not leak coolant at the access plate. If it did it would dump into the timing case and have to fill up the entire crankcase fefore it started to spill out of the access plate. Something else in the area has to be leaking.
Old Feb 1, 2012 | 09:52 AM
moNYtx's Avatar
Just fixed this issue about 4 months ago. We changed the head gasket and a bunch seals.
Old Feb 2, 2012 | 02:41 AM
CMax03's Avatar
Did you clean everthing up?
Old Feb 8, 2012 | 06:46 PM
Well i found out the problem....there is a small crack in the block lol
Old Feb 8, 2012 | 06:50 PM
BigLou55's Avatar
wow, any idea what caused it?
Old Feb 8, 2012 | 07:06 PM
Gismo-T's Avatar
Yea CMax03, that's what I meant by the small hole of the timing cover!
Come on man...
Old Feb 8, 2012 | 08:12 PM
WhiteMaxima9600's Avatar
wow a crack in the block, how many miles u have? wonder what caused that
Old Feb 9, 2012 | 06:46 AM
CMax03's Avatar
I see what you're talking about...My bad you were correct!
You're also correct...I pulled my w/p and the shaft seal and bearing were destroyed and the oil pan was full of oil , but I see how those two seals separate the oil side frm the coolant side and the weep hole is between them which has it's own drainage galley thru the timing cover/block! My Bad guys
You must of cracked you're block cause there was no coolant....There will but no indication on your temp guage if there is no coolant...Sorry to hear that bad news..... The VQ30 is easy to come by...good luck!
