Drivers Side halfshaft issues.....
Old Feb 3, 2012 | 05:49 PM
Boothers96's Avatar
ok so im replacing my DS halfshaft this evening and its been a pretty straight forward job before.....i seem to have some issues getting it to come out of the trans....i have everything unbolted, lower strut bolts, wheel hub bolt, and caliper out of the way....and i pulled on the half shaft for until i felt the inner knuckle pop out of joint....then i thought id try and pry it from the trans w a pickle fork and a hammer and lastly wrapped some wire around it with some chain and tried to yank it out.....it has since come out roughly 1/2 in and stops there....dont want to damage the trans and jw if theres any other suggustions.....
btw car is 5MT, non abs, non LSD.
Thanks.
Old Feb 3, 2012 | 10:44 PM
Phreakonaleash's Avatar
This happened to me years ago.
Typically, what you'll want to do is push it back in, and yank it out in one pop. The circlip can be a real pain sometimes.
But, Nothing would go for me. I ended having to fab a pipe/bar to go through the differential, and allow me to hit the end inside of the transmission with a 3lb maul.
Not really recommended in any way, but that's what I had to do.
Old Feb 3, 2012 | 11:18 PM
CMax03's Avatar
Use a prybar or large screwdriver to remove it!
Old Feb 4, 2012 | 11:38 AM
Trini Boom's Avatar
Out of curiosity, is this your OEM one? Because I still have mine but I see the rubber boots starting to get brittle. Is this your same problem or you replacing the whole thing instead of replacing the boots?
Old Feb 6, 2012 | 12:13 AM
Boothers96's Avatar
finally i got it out....used a 3lb maul and the pickle fork and gave it everything i have and it finally came out.....now im stuck gettin it in.....i shoved it in with all my might and theres still that 1/4in gap and its slowly dripping gear oil still.....i dont want to mess up my diff is there a seal i shouldve replaced? or how could i shove this in anymore? all help is super appreciated!!! i need this car on the road lol....this wasnt meant to b an entire weekend ordeal....
Old Feb 6, 2012 | 11:30 AM
maxed_out_99's Avatar
Pull it back out and use the the joint to help you out pull the axle until you see the cv boot expand then pop it in the trans like a pogo stick kinda way do that until its seated
Old Feb 7, 2012 | 09:38 PM
nitromax's Avatar
i've tapped on mine with a hammer after getting the axle in as far as it would go, and then get the joints as lined as i could. a couple of good whacks & it popped in. if you use a block of wood, you're sure not to damage the end of the axle.
Old Feb 8, 2012 | 10:39 AM
cashoit's Avatar
damn this job sounds like a PITA
good luck man
Old Feb 8, 2012 | 07:07 PM
Boothers96's Avatar
What makes it more of PITA is the cv grease....i swear everytime i replace an axle i manage to get that frickin grease EVERYWHERE!!! ugh....anywho i cant believe i cut the inner boot....i put a bar against it and was hittin it with the maul and it slipped an cut thru it....so AZ had to ship another axle in and im gettin it tomorrow and will be installing this weekend....ill review afterwards....
Thanks for all your help....
Old Feb 14, 2012 | 08:14 PM
Boothers96's Avatar
ok as a final follow up to this whole pile of crap.....i was able to get my hands on another axle from AZ after a few days and being swamped at work i decided to have a local shop whom i trust install it. for some reason the axle was stuck in the trans and they couldnt get it out....they even bent a 7 ft pry bar trying to get it out.....they had to take off the pass side axle and pound the axle out of the diff.....the reason behind this? a faulty c clip on the end had mushroomed and wasnt allowing the axle to move at all, in or out.....the said theyve never seen this before (not the first time someone has used that phrase in a negative way with this damn car lol)...whats worse the new axle had the same faulty clip in it. the shop replaced the clip and put it all back together....$125 in labor later and it was done. im not getting AZ axles again....next time its raxles......
Old Feb 15, 2012 | 09:11 AM
99zx2's Avatar
^^ sounds like a decent shop. not bad for labor.
Old Feb 15, 2012 | 09:35 AM
aackshun's Avatar
+1 You came out of this one easy.
D/S Axles suck bawls, esp. if your transmission blew up and there's pieces of it in the axle preventing it from getting out... We had to take apart a transmission one time to get an axle out of the diff.....
Old Feb 18, 2012 | 01:57 AM
Boothers96's Avatar
hey, aackshun, says in ur sig ur lookin for 16s for racin....i got some n/a z32 rims w some crappy fuzion hri tires id unload pretty cheap....if ur ever in the tyler area....pm me if ur interested.....
boomerbrian
Oct 31, 2018 10:25 AM
03VQMAX
Nov 10, 2015 03:39 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
