MAF jerking backprobing
Old Mar 6, 2012 | 09:52 PM
thegodson1's Avatar
So recently after changing the Valve cover gaskets touching the wiring harness that led to my MAF would lead the engine to cutout just my touching the wiring harness that connects to the MAF, then today afterschool it started jerking city driving. checked out the positive wire (backprobe) checked good, checked negative and it checked good, however checking continuity black lead on negative battery terminal and red lead on the MAF Signal Output Circuit wire (white) I got 4.53ohms, does this mean this white wire is bad? however with engine on and testing it, it tested out fine, my MAF is fine something is up with the wiring. Is 4.53 not good or normal?
Old Mar 7, 2012 | 10:19 AM
cashoit's Avatar
the connector on the MAF is prolly bad. U can try to resolder the connection
Old Mar 8, 2012 | 10:42 PM
thegodson1's Avatar
but is 4.53 ohms mean the wire is bad? or am i just measuring wrong I put the negative lead on the negative terminal with Engine off Key OFF an postive lead one the MAF signal wire
TallTom
57
Oct 14, 2025 05:16 PM
Melissa40
Jun 30, 2017 10:04 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
