ddm tuning hid kit install issues
Old Mar 15, 2012 | 06:42 AM
sickwitit's Avatar
So i got a hid kit from ddm tuning (i know i know kill me now but my retrofit will be soon.) When going to install, i had the ballasts fully connected ready to plug in
Now this little blue piece
Is supposed to connect to this little black piece correct?
Anyways when trying to set it up it did not connect properly, it was very loose with the connection, it didn't just snap in, and when trying to plug it in, lights did not work. Am i doing something wrong here, i installed hids on my 06 altima just fine and don't remember having this issue, this is the 9004 kit from ddm, am i missing something?
Old Mar 15, 2012 | 08:24 AM
ShocknAwe's Avatar
Yes, connects to one of the factory connectors. I only have one connector, same blue one, that connects to one factory connector and the other factory connector doesnt connect to anything. You'll figure it out, not a million wiring options for headlights
Old Mar 15, 2012 | 08:36 AM
JNCoRacer's Avatar
Just the tip.
Maybe that blue plug is wired as a 9007 connector?
Old Mar 15, 2012 | 08:45 AM
sickwitit's Avatar
maybe? I'm not too sure, seems like it should just connect but it doesn't fit properly? maybe they sent me the wrong set....
Old Mar 15, 2012 | 08:52 AM
ShocknAwe's Avatar
mine is def for 9007
Old Mar 15, 2012 | 08:55 AM
Gismo-T's Avatar
B!tch We Got a Problem
Maybe the tab on the black connection is opened up too much, which wont allow it to lock with blue connection. Had the same problem, ended up just taping it to secure it.
Old Mar 15, 2012 | 08:56 AM
sickwitit's Avatar
but even when connecting it just to test it out to make sure the bulb lights it didn't work? and i don't think it'd be 9007 since i put in a 9004 bulb from auto zone a month ago
Old Mar 15, 2012 | 09:03 AM
ShocknAwe's Avatar
try taking the connectors out of the blue thing so you can interchange them inside the factory connector. might have it switched up. 3 wires right?
Old Mar 15, 2012 | 09:09 AM
KnightRyder8776's Avatar
Back when I had the same kit from ddm I had to switch the positions of the wires for the lights to work. And the blue connecter never fit properly so I just electrical taped that b**ch
Old Mar 15, 2012 | 09:10 AM
Two wires...looks like only low beam
Old Mar 15, 2012 | 09:17 AM
ShocknAwe's Avatar
ok well you most likely have the wiring wrong. take them out of the blue connector by compressing the tab on the metal with a pair of pliers and have everything else hooked up and find a combination that works. My guess is going to be the 2nd and 3rd female ends on the factory connector. Wrap it in electrical tape when your done to keep water out as well, especially if its loose
Old Mar 15, 2012 | 09:24 AM
sickwitit's Avatar
inside of the blue connector there are 2 metal prongs, so 2 wires to the blue plug, and in the black connector for the harness it has 3 slots for 3 prongs, sound familiar? and it is a low beam only kit
Old Mar 15, 2012 | 09:41 AM
Yup, low beam only.
On the blue connector, make sure the red wire is in the middle slot and the black one is in the slot on the right. If not, you'll have to switch them around. Search YouTube for how to re-pin a 9004 harness.
Old Mar 15, 2012 | 10:20 AM
sickwitit's Avatar
I see i'll try that, sucks they should've sent it ready to plug and play
Old Mar 15, 2012 | 12:20 PM
Nope, it's a cheap kit. Gotta DIY.
Old Mar 15, 2012 | 12:28 PM
sickwitit's Avatar
"do you like to do it yourself? well if the mood strikes....hows the mood striking you now?!?!" lol
Old Mar 15, 2012 | 04:51 PM
GGENIUS's Avatar
shoulda went with hidsrus
Old Mar 15, 2012 | 06:15 PM
sickwitit's Avatar
Problem solved, switched the red and black connectors in the blue plug like Chris said and voila, working like a charm
Old Mar 15, 2012 | 06:19 PM
I'm a genius.
Old Mar 15, 2012 | 06:55 PM
Gismo-T's Avatar
Good that you figured it out, you should of spent the extra $20 for the hi/lo kit. Waiting for mine to come in from DDM, hopefully no problems.
Old Mar 15, 2012 | 07:16 PM
sickwitit's Avatar
I might get that later, but I never use the high beams and they are PLENTY BRIGHT lol
Old Mar 15, 2012 | 07:28 PM
If it's a halogen "high" beam sort of hi/lo kit, it's not worth the extra $20.
Old Mar 15, 2012 | 11:18 PM
styliztik's Avatar
https://www.ddmtuning.com/support/in...emid=1&nav=0,1
and I used this
http://www.cumminsforum.com/forum/at...e-90049007.jpg
obviously we use the one on the left. also make sure the prongs in the socket are straight so they slide in.
Old Mar 16, 2012 | 04:33 AM
GGENIUS's Avatar
yeah those things are retarded. the "high" beam is half as dull as my low beam.
GGENIUS's Avatar
but mine came like that at no extra cost so idgaf
Old Mar 16, 2012 | 06:03 AM
CMax03's Avatar
Easy fix! but you should've spent your $$$ on a Bi-Xenon setup....glareshields with xenon hi beams and xenon low beams....and just right for a halogen housing! Reduced glare and a true visible hi beam system!
Old Jul 22, 2012 | 03:52 PM
JDM BOIIA32's Avatar
OP was your hid kit a low/hi or just one
i have the same ones but somehow its only hi OR low depending on how i switch up the 2 red wires.
let me know thanx
Old Jul 29, 2012 | 03:44 PM
tallguesse07's Avatar
ddm changed there kit so its a hid high beam not halogen now had them but didnt set it up on my car cuz i was thinking of retrofiting some projectors on to the cifero headlight assembly best part bout living in sd i can just drive up to ddm and return them at there shop
VQ'ed
69
Aug 27, 2020 12:29 PM
Finkle
Sep 27, 2015 09:53 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
t6378tp
Aug 24, 2015 07:03 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
