Bellows Boot and Fluid Leakage
#41
That's the timing chain tensioner access hole but there is no coolant in that corner of the engine. When you have your car parked, where exactly from the bottom do you see the coolant sitting or dropping directly under? Chances are its one of two things:
-Water Pump
-Coolant hose behind rear valve cover
-Water Pump
#42
Well, changed out the pressure sensor this morning and it seems the old one was not even tightened all the way. Put the new one in anyway since I had it. Cleaned the area of "our" suspicious leak and put the stop leak in. It says the leak should stop within 200 miles so here's what it looks like now after being cleaned. It'll take me a little over a week to do 200 miles so I'll report back.
![](http://i1112.photobucket.com/albums/k500/2brogixxer/IMAG1192.jpg)
#43
I'm experiencing another problem. Since changing the transmission oil, my car seems to shift smoothly when cold but gets stiff when the car is all warmed up.
I used Red Line 75w90 MT90 GL-4 gear oil as recommended by most people in this sub-forum. Any suggestions as to why I may be experiencing this?
#44
Man, you can't catch a break. Get one thing fixed, move onto the nxt. Gotta love old cars.
Is it stiff but smooth when warm or stiff and rough shifting when warm? The only thing I could think of if its still smooth is that the gear our is new, thus thicker making it feel stiff. I dunno for sure tho. Maybe start a new thread for that
since me and you seem to be just having our own private discussion in this one
So, like I said, changed the oil pressure switch, checked for leaks there today and it dry. One down. The leak near the tranny is still dry as well so ot can't be too major of a leak.
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
#45
^^^ Give it a few drive and parks and it will return if you didn't replace the half moon seals. That stop leak stuff will give you more problems especially with your timing chain tensioner. Rattling to come....if not already there.
#46
How could that make the tensioner rattle?
#47
i think trini boom is trying to say that the timing chain tensioner will begin to clog up with the stop leak stuff and that it will then not be able to hold/exert enough pressure on the timing chain and that this will lead to timing chain rattle.
#49
Thread revival alert. Just had my Upper pan seals replaced along with front and rear valve cover gaskets and axle seals. Leak seems to be gone so mine was another case of Upper Pan Half Moon seals gone bad.
#51
Bath in brake clean
Edit: Thanks for your advise throughout this whole thread, otherwise, I may have listened to the mechanic and done the RMS for no reason.
06-06-2017 02:01 PM
knight_yyz
11-01-2015 01:34 PM
Need help
23
10-02-2015 08:56 AM
