air conditioner problem
Old Mar 26, 2012 | 02:37 PM
JEFF6898's Avatar
My a/c is starting to blow at differant speeds. Fo example I have to the setting on 4 high speed. It will blow hard out of the vent then all of a sudden start blowing as if somoen switched it to low speed, then blow hard again, the low ect. It will do this all gthe time no matter if I am sitting at idle or driving at a steady speed. Any ideas?
Old Mar 26, 2012 | 02:50 PM
DennisMik's Avatar
this is probably due to the fact that the temperature in the cabin has reached the control panel setting. It is a built in feature.
Old Mar 26, 2012 | 03:13 PM
Amerikaner83's Avatar
Dennis - I assume what you mentioned is a feature of the AUTO climate control...what if OP has manual climate control?
Old Mar 26, 2012 | 03:41 PM
DennisMik's Avatar
My 97 has the manual controls and it does it. I was used to the auto climate controls on my other max's doing that and didn't expect the manual to do that. But it does.
Old Mar 26, 2012 | 04:05 PM
hmm. Learn something new every day :-) Guess i know what to expect in my 99 then here in a few months
Old Mar 26, 2012 | 04:06 PM
JEFF6898's Avatar
Guess I should have mentioned that 98 Maxima GXE manual a/c
Old Mar 26, 2012 | 04:38 PM
beegeezy's Avatar
My manual a/c does something like this too. If I have it set on the second lowest speed, for example, occasionally when I take off from a stop the fan speed will increase...as if I had just pressed the recirculate button.
Old Mar 26, 2012 | 05:07 PM
TripleBLACKmax's Avatar
my 99 does not do that,.. it only works on 4. blower motor resistor
Mar 12, 2020 12:06 AM
Smackasmith
Feb 1, 2016 12:40 AM
thenewguyy
Sep 12, 2015 11:12 AM
conansriver
Sep 11, 2015 10:26 AM
lux97Max
Sep 4, 2015 05:42 PM
