Do you buy the front wheel bearing as a whole assembly? or by itself?
Old Mar 27, 2012 | 12:49 PM
kroze's Avatar
I need to replace my front wheel bearings and I don't know where to order it. I checked the autozone website and it listed as 2 separate pieces (wheel hub vs bearing)
Isn't easier to just buy the whole thing assembled? Wouldn't it be easier to install?
Does anyone know the part # for the wheel hub with/bearing preinstalled?
Old Mar 27, 2012 | 01:20 PM
If you buy the hub it'll probably come with a new bearing already pressed in.
Old Mar 27, 2012 | 03:31 PM
ThreePointO's Avatar
the hub doesn't include the bearing. But if you buy a bearing, it will need to be pressed into the hub. If you dont have the capability to do that i suggest you try to pick up a hub from a junk yard w/ a good bearing.
You may be able to find a shop that will just press in a bearing for you if you bring them the hub but i dont know. Ive had a few bearings done on my cars and it was about $275
Old Mar 27, 2012 | 04:23 PM
BigLou55's Avatar
mine sure did
Old Mar 27, 2012 | 06:15 PM
315max's Avatar
those bearings are a PITA to change
Old Mar 27, 2012 | 09:17 PM
eddie982's Avatar
Lucky me, picked one up for cheap from classifieds.
Old Mar 27, 2012 | 09:44 PM
ShocknAwe's Avatar
Im sure rockauto has some already with bearings. Its like control arms. Might as well buy the whole assembly. Who buys just the bushings?
Old Mar 27, 2012 | 10:08 PM
VisciousMo's Avatar
Inspect hub to see if it is damaged first. Bearings cost anywhere from $25-$75. Shops should charge $20-30 to press that in.
Also, avoid Duralast bearings from Autozone.
Old Mar 27, 2012 | 10:12 PM
ShocknAwe's Avatar
if your gonna have me in your sig then you have GOT to change the picture back
Old Mar 27, 2012 | 10:17 PM
VisciousMo's Avatar
haha shock. I'll have something in the next couple weeks to get your attention again! new sig pic was right after I installed coils. meaty tires are meaty.
Old Mar 27, 2012 | 10:20 PM
Quickywd01's Avatar
You are an idiot.
HOKUSMAX
Nov 13, 2017 04:34 AM
boomerbrian
Nov 8, 2015 05:10 PM
twotonezed
Aug 16, 2015 11:41 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
