Bank 1 Sensor 2 - will this fit
Old 08-05-2019, 04:52 AM
  #41
Tony Cervantes's Avatar
Bank 1 sensor 2 97 nissan maxima fed emmision where is of location
I have code p0141 oxygen sensor . 97 nissan maxima i have a fed emmision .so where is of location . Thanks for help
Tony Cervantes is offline
Old 08-05-2019, 05:00 AM
  #42
Originally Posted by bobflood
you're close - sensor 2 is always "post" (after) cat. Fed spec cars have one post cat sensor, identified as bank1 sensor 2; cali specs have two post cat sensors. In our maximas, bank 1 is the cylinder bank at the rear of the engine compartment; bank 2 is at the front of the engine compartment.
so i have a code p0141 say bank 1 sensor 2 i have a fed specs so is aftercat or before ,? And is upstream or downstream can help me guys thanks
Old 08-05-2019, 05:27 AM
  #43
Originally Posted by 2brosgixxer
ok, mike, you need to change the downstream one right? Iirc bank 1 sensor 2 is downstream. This would be the one by the cat. Here is a link for down stream... 4 wires http://www.ebay.com/itm/new-direct-f...76df41&vxp=mtr
upstream has 3 wires and those 2 i believe are interchangeable with each other.
so of bank 1 sensor 2 is aftercat ? On fed specs???
Old 08-05-2019, 06:17 AM
  #44
I have a 97 nissan maxima gxe fed specs somebody help me whre is of location bank 1 sensor 2 . And if is upstream or downstream . Thanks
Old 08-05-2019, 09:11 AM
  #45
KP11520's Avatar
It's by your rear Cat, after the Y-Pipe and Rear Cat. (just after) The model number you need is NTK 24630. The two front (Upstream) ones part number is NTK 24525. You have a total of three. Here's the rear:
Amazon Amazon
I'd probably replace all three. Certainly cheap enough when you shop for best delivered price.via Google.
Took me 5 minutes to find this, including the info of the configuration for a Fed 97. Maybe that's why you posted 5 times with zero results. If you can't research HERE, why would anyone think you can handle this. So why bother. No info on your profile either. Typical.
NTK are the manufacturers of what your car was delivered with.
KP11520 is offline
Old 09-24-2020, 11:35 AM
  #46
my car is 97 maxima is federal spec how many oxygen sensor have and you have pic to see whre is of location..thanks
Cyphar
05-16-2015 07:51 AM
slow_yota
10-12-2009 05:05 PM
super6
06-30-2006 04:28 PM
Seyser
10-21-2005 04:10 PM
sureal00
11-12-2003 11:49 PM
Quick Reply: Bank 1 Sensor 2 - will this fit
