Would a vacuum leak really drascally decrease MPG in our cars?
Old Apr 1, 2012 | 02:14 AM
S1cTech's Avatar
I am trying to figure out other then a tuneup what needs to be done to improve my 16-17mpg maxi. okay yeah I know it is an old car with 213k miles but really. $40 bucks of 93 and I only get 204 miles until orange light. Granted I do live in the city and do some highway driving but this is "MADDNESS" lol
I hear a little vacuum sound when I put my head near the engine but I really can't locate it but I never had this leak before I decided to rip off half the upper manifold to fix and clean out the EGR issue these cars love to have. I have year old Michlian tires that have proper psi, I gave it a tune up 2 years ago with all plat lasers. I will do another one this summer. I changed the fuel filter from a 300zx I did 2 years ago to a maxi one this past fall.
There is only one thing that makes me think this is causing an issue and my mpg but I am not entirely sure if the knock sensor would have anything to do with it. I have had knock sensor codes in the past. Tons of them. Went to junkyards and put like 3 different ones on through out a few years span and they would go. I know, I know, I could of spent $50 bucks on a new one, but I didn't wanna spend $50 bucks on these things if the junkyard ones up to 3 kept throwing codes after a while.
So I decided to do the Resistor mod on here because the car really blows at 40less HP as it feels and I keep that on and only keep premium in to keep the knock reduced as much as possible, but do you really think that may be my issue? I gotta admit I never had amazing gas mileage for a few years but now that gas is already over $4 a gallon again. I am taking it more seriously. Just to think 10 gallons of gas gets me 200 miles is absurd.
Old Apr 1, 2012 | 05:08 AM
njmaxseltd's Avatar
Put a new knock sensor in. It will pay for itself in 2 or 3 tanks of fuel if it's bad.
O2 sensors will cause poor gpm as well even if there is no code set.
A vacuum leak will make you run lean and should actually set a dtc code for it.
Old Apr 1, 2012 | 09:15 AM
S1cTech's Avatar
hmm, yeah I never replaced those, what is a cheap place to buy them? I really don't wanna spend like $50 a plug on an assumption tho that those are bad, but yeah I did never replace them. I have a y-pipe too.
Old Apr 1, 2012 | 02:48 PM
2brosgixxer's Avatar
If the link works, this is the one I bought with zero issues so far. http://item.mobileweb.ebay.com/viewi...id=24115399858
Edit: wait, were you asking about where to buy the o2 sensor or knock sensor? For the o2, there was just a thread done with the title something like "bank 1 sensor 2 will this fit" search for that, he found some o2 sensors for $30.
Old Apr 1, 2012 | 06:01 PM
S1cTech's Avatar
o2.... I think it is pointless to replace the Knock sense I already did the resistor mod and after 3 junkyard ones failing it is probably a waste of time to chance a $50 one that could also have an issue or a chance my engine is always knocking now.
Old Apr 1, 2012 | 07:26 PM
beegeezy's Avatar
That's because the $17 ones on ebay are better.
Old Apr 1, 2012 | 07:41 PM
There's no sense in throwing in a KS if you've got it bypassed with a resistor already.
I don't think you have a vac leak unless you've got a fluctuating idle which you don't mention.
What other maintenance have you done? Maybe it's time for a new front left O2 sensor, maybe plugs, filter, TB/MAF/IACV cleaning etc..
Old Apr 2, 2012 | 05:45 AM
S1cTech's Avatar
Did TB, Put in a new maf last spring, and IACV cleaning last year when I did the EGR valve cleaning. I should look into the o2 sensors though if you guys really think that will help. Also, The idle does dip a lot when I go into neutral right away at say a stop light. It is pretty annoying like it will dip to 300 rpm when I let it go and it will go back up to 500-600 again.
Old Apr 2, 2012 | 06:10 AM
cashoit's Avatar
hey man...
a bottle of chevron techron goes a looooong way
Old Apr 2, 2012 | 08:48 AM
felorojas14's Avatar
To help locate a vacuum leak. Try spraying carberator cleaner over all the vacuum lines. If there is a leak the cleaner will get sucked into the line and your idle will fluctuate drastically. Then from there you can pin point the leak. Hope that helps.
Old Apr 2, 2012 | 01:26 PM
S1cTech's Avatar
good idea. I will give that a shot... Thanks!
Old Apr 3, 2012 | 05:05 PM
S1cTech's Avatar
holy ****. lol, I got did a code check and I am getting this...
2 codes for P1105 MAP sensor. pressure bar switch solenoid circuit I really forget where that is...
and 1 code for P0138 o2 sensor voltage bank 1 "Circuit high"
Old Apr 4, 2012 | 12:04 PM
S1cTech's Avatar
Anyone know anything about the MAP sensor? And where can I buy a cheap O2?
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
N2deep
Aug 16, 2015 08:30 PM
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
