4th gen max a/c question
ok i just bought this max se great car fresh swap lowered lip yellow fogs but the a/c system isnt hooked up the only hose i have is this one http://www.theautopartsshop.com/sear...h=FS/56909.jpg and i know i need this one http://www.theautopartsshop.com/sear...h=FS/56908.jpg now ware dose the one i need (the second pic ) bolt into. i know one end plugs and bolts into the compressor but ware dose the other end go?
Dryer is a small canister (looks like a coke can only a little taller) near the battery. Anytime the A/C system is opened that needs to be replaced as it absorbs moisture in the A/C system and it is probably no longer any good. Your A/C would probably still work ok without replacing it but it will definitely not be as efficient and it is only like $10 on rockauto.com. So once you replace the one line you need and the dryer, then you need to evac the system which you can rent the vacuum pump at autozone, and then recharge (preferrably with U/V dye in the refrigerant so you can see if anything else is leaking).
Finkle
Sep 27, 2015 09:53 PM
95Maxi
Aug 25, 2015 08:01 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
