this squeak needs to GO!!!!
My mind is going insane now.
I've had this squeak since 120k and now at 136k its just gets a little more loud and annoying, its only on the pass side. I get this squeak over bumps and humps
I've started with replacement of the wheel bearing because it was wobbling, sway bar bushings and endlinks. Most recently i got my control arm/balljoint replaced as well. STILL the problem is still there, heck i think it got a little more louder!
Only thing on the side is left is tie rod end and the whole strut assembly (maybe the mount is bad). I got the tie rods on order. After the tie rod, is there anything other then that strut assembly?
Control arms bushings. Does it sound like this:
http://www.youtube.com/watch?v=Sniup...5&feature=plcp
-wheel bearing
-sway bushings and endlinks
-control arm
-CV axle
all have been replaced recently within this month. None shifted, made it louder/quieter. Only two things left which is a strut mount/bearing/isolater and a tie rod. I dont think its the tierod but its cheap to replace so i'll just do that.
@ that video, that control arm bushing noises is not what i have. Completely different type of squeak. That bushing squeak sounds like a old door that needs to be lubed.
Will look into replacing the whole strut assembly, yes they are OEM stuff still at 130k
MikesChevelle
Aug 7, 2015 05:57 PM
Maxima95GLE
Jan 3, 2001 01:35 PM
Eric L.
Jan 1, 2001 01:54 AM
