Is this a CA Emmissions car?
Dumb Question:
On the label under the hood, I see "this car conforms to US EPA and CA Emissions Regulations..."
Does that mean this is considered a CA emissions car?
Thanks,
Thanks,
more than likely.
what's the year? the 99's are teh only CA spec maximas that are annoying, the other 95-98 years are ok.
Quick way to tell: get down on ground near driver and look towards the middle of the car, you'll see the cat. converter. If it's got an O2 sensor sticking out the back, it's FED spec. If not, then you're Cali spec.
Or if it is stock or not heavily modified, you can pop the hood and check the wire harnesses on the front of the engine block. Fed specs have just two things connected there, an O2 sensor and something else.
The Cali spec has two o2 sensors and two other something elses. like here. Below where the plastic valve cover says V6 3000:
I think this means I have FOUR O2 sensors... I will have to check under there again. At least three of those front connectors are o2 sensors... don't know what the fourth one is.
On the '99, is the connector for the bank 1 upstream sensor located in front with the rest of the O2 connectors? Or is it towards the firewall?
I only see three connectors that look like O2 type sensor connectors on the front array, and I've found all three of those sensors below. I'm figuring there's a fourth I need to find that is the one that needs changing.
As soon as I get an hour to go get dirty again I am going back under, but if I need to be looking somewhere else, that would help.
Thanks,
Thanks,
The engines are the same. Its all the emissions equipment bolted to it that is different. You can't just swap everything over either. You'd need to swap the EGR, LIM, front exhaust manifold, Y pipe, ECU, just to name a few. Then you need to wire it all correctly to make it work.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
