front shake
Old Jun 23, 2012 | 04:43 PM
ibracey's Avatar
front shake
i was driving down the road tonite coming home doing about 70-80 and the steering wheel was shacking real bad. now i have a few ideas but i would like everyones opinion. i think it maybe tie rod ends or maybe my cv joints but im not sure
Old Jun 23, 2012 | 07:38 PM
T_Behr904's Avatar
Start with a tire balance and go from there. It's possible a wheel weight might have come off.
Old Jun 23, 2012 | 08:11 PM
rf97's Avatar
Rotate wheels from front to back and see if that makes a difference
Old Jun 23, 2012 | 10:58 PM
infinimax96's Avatar
99% of the time it's improperly balanced tires. Especially if it's only in a specific speed range. Example: only shakes from 73-76mph. Any speed faster or slower there is no shake, it's most likely a balance issue.
Old Jun 24, 2012 | 04:20 AM
ibracey's Avatar
yea it started out just under 80 and now its over 80. i will try that first and see what happens thanks everyone
Old Jun 24, 2012 | 06:09 AM
milo2223's Avatar
+1
Old Jun 25, 2012 | 01:00 PM
ibracey's Avatar
ok so i stopped by the shop today when i got off work to see if they could look under the car, found out i need 4 new tires cuz the inside of them all are shot and i need lower ball joints plus a 4 wheel alignment. so i am goin to save up the money and do the ball joints myself and then take the car for an alignment
Old Jun 25, 2012 | 02:43 PM
mikeg75's Avatar
I had a similar shimmy/shake at highway speeds and took the car to the tire place nearby, to check on alignment / balancing / rotation. The tech immediately noticed that the front tires hadn't been rotated with the back ones, and he thought a simple rebalance and rotation would fix the problem. Sure enough, problem solved for ~$65. If the alignment were off, it would pull, whereas if it simply shakes / shimmies, then it's often balancing or rotation that is needed, per the guys at this place.
wyobbagy
Jan 3, 2023 12:03 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
