Loud Sound From Engine (video)
Old Jul 12, 2012 | 10:45 PM
Centimetro's Avatar
Hey guys,
I have a 1997 5spd, drives fine. Got some gas today, drove a few miles to the grocery store, came back, and when I was a few blocks from home the noise started. At first I thought it was a jackhammer or something outside (it wasn't super loud yet), but after I stopped at a stop sign it was apparent it was coming from under my hood.
Car continued to drive fine -- I turned it off and on again, then parked it.
Tried starting it a few hours later, and that's when I took this video -- the sound is now louder and more consistent than before. It is loud at idle and appears to get louder(?) when revved in neutral - revving sounds pretty weird actually. I rev a couple of times in the video below.
Video:
http://youtu.be/ofc-eX8FYrI
Oil level looks good.
Any ideas? I thank you for any experience and wisdom you can share, I'd love to get an idea of the nature of the beast I'm dealing with. I tried searching around a bit and found some opinions on other's engine noises, but I was hoping there would be some clue to someone out there in my personal video
Thanks in advance for any help, I really appreciate any responses I get.
P.S. I noticed a strange noise that I don't believe I've heard before when turning the power on (but before turning the key fully to crank the engine), I've included that in the video as well in case its relevant (2-3 seconds)
Old Jul 12, 2012 | 10:52 PM
Amerikaner83's Avatar
any codes?
Have you done ANY under-hood work at all recently?
Video sorta sounds like my wife's Subaru...piston slap. But I'm not sure on that. It's NOT timing chain rattle afaik...so that's good.
Old Jul 12, 2012 | 11:29 PM
Centimetro's Avatar
oh yea, no CEL so I originally didn't pull codes, but I did just now just to make sure and it came back with nothing reported (0505)
and nope, haven't done any work under the hood recently
Old Jul 13, 2012 | 05:01 AM
njmaxseltd's Avatar
Um, is there oil in it?
Is the oil warning light on, does it even work?
Sounds like its running with no oil pressure and by now that engine is toast.
Old Jul 13, 2012 | 06:10 AM
tothemax2003's Avatar
that sounds like your flywheel is coming apart , thats conected to the converter and transmission.I dont think its your motor.
Old Jul 13, 2012 | 06:24 AM
max ride 41's Avatar
get a long screwdriver and listen with your ear on different spots on the block until you find the spot where its loudest. that will give us and you a better idea as to what's going on.
Old Jul 13, 2012 | 06:48 AM
styliztik's Avatar
1: fly wheel rotates, not back and forth.
2: he doesn't have a torque converter cuz he's 5mt.
Old Jul 13, 2012 | 07:16 AM
he claims oil level is fine
Old Jul 13, 2012 | 09:51 AM
Boothers96's Avatar
Car could have oil in the pan but no oil pressure.....either pump went out, screen clogged completely, bearings worn like crazy etc....
Old Jul 13, 2012 | 11:51 AM
asand1's Avatar
Cars either have a flywheel and clutch, or a flex plate and converter. Never a flywheel AND torque converter.
OP, you have a bad rod knock due to a spun rod bearing. Any 7,000 RPM shifts earlier that day?
You didnt let TravisCadello drive it did yah?
Old Jul 13, 2012 | 11:53 AM
asand1's Avatar
I think any of these problems would result in a higher frequency rattle, this sounds like one rod to me.
Old Jul 13, 2012 | 01:05 PM
Centimetro's Avatar
Thanks for replies
Yes, there is definitely oil in the pan. It's pretty clean too, and not leaking or anything like that. Can't vouch for the pressure since I don't have a way to measure that, but the idiot light is not on and never came on. I would have loved to have some kind of warning
After looking up other people's videos of rod knock on YouTube, I think you're right... I mean I knew it sounded bad and I kinda expected the worst but since nothing actually happened and the engine isn't that old I was giving my car the benefit of the doubt
WTF? Do these things ever spontaneously happen? I shift normally, and I just got back from a small road trip the previous day with zero performance or noise issues, I'm confused.
Old Jul 13, 2012 | 01:09 PM
when you turn the car ON (but not start), does teh low oil pressure light in the dash come on and them go off in 3 sec. like it's supposed to? Maybe the bulb is burned out...
Old Jul 13, 2012 | 01:34 PM
Centimetro's Avatar
Yes, it does, and since this happened I double checked to make sure its still working. thanks, I meant to mention that
Old Jul 13, 2012 | 07:16 PM
Trini Boom's Avatar
Ok so if your oil pressure switch is working, you should definitely check for oil pressure. For someone that does regular driving, doesn't seem like that should have happened. How many miles on the engine?
Old Jul 13, 2012 | 08:40 PM
Centimetro's Avatar
Just hit 100,000 a couple of weeks ago, of which I've personally put the last 10,000 on (In about 2 years)
Old Jul 13, 2012 | 08:47 PM
jluis77's Avatar
timing chain tensioners
its hard to identify the problem by the video,but check if its a rattle coming from the timing chains side of the car...if its like a rattle noise, it might be the tensioners not making pressure on the chains.
Old Jul 13, 2012 | 08:57 PM
Nealoc187's Avatar
SLOW
rod knock homie. either that or a serious valvetrain problem.
either way that engine is toast.
Old Jul 13, 2012 | 09:09 PM
renots's Avatar
Atleast if it's blown you had a warning, mine went an didn't even make a noise.
Old Jul 13, 2012 | 10:12 PM
carsnwomen91's Avatar
what sort of gas did you put in it? sounding like a healthy diesel lol could be VERY bad knocking but it wouldn't sound so loud at idle and wouldn't be so consistent
btw you can see his oil light on the dash when it starts up.
Old Jul 14, 2012 | 05:18 AM
WielkiWaac's Avatar
MaximaDriver
Yea, I would say you have problem with your valves. If you rev your engine, is that noise "clicking" faster?
Old Jul 14, 2012 | 07:37 AM
VisciousMo's Avatar
Noob Question: Can someone link me to a oil pressure sending unit for a major parts store. I'm having issues finding one
Old Jul 14, 2012 | 08:55 AM
SterlingMistMax's Avatar
Look down at the crank pulley to make sure its not coming from there . if its the crank pulley coming apart you will see it wobbling and the belts will look like they are coming off the other pulleys and not lined up right . yours sounds a lot louder than that but you have the hood half closed and looks like your in a parking garage so might be why its louder . im hoping for you that is what is wrong .
Old Jul 14, 2012 | 08:57 AM
holymoly's Avatar
belt tensioner?
Surely something with the belts
Old Jul 14, 2012 | 09:08 AM
Old Jul 14, 2012 | 09:13 AM
Boothers96's Avatar
Amerikaner remarked that op said oil level was fine....i was merely posing a scenario where the oil level could appear fine but not actually be circulating causing premature bearing wear/failure since it sounds like a spun bearing.....
Old Jul 14, 2012 | 09:24 AM
asand1's Avatar
Lol at the tensioner and valve comments. This is a loud and deep knock at a low frequency. Its a rod bearing or broken piston. Time for a 3.5 swap :-)
Old Jul 14, 2012 | 09:27 AM
asand1's Avatar
I undersant the point of your comment, I just don't think its the case hear or you would hear more of a rattle than a knock.
Old Jul 14, 2012 | 10:36 PM
any chance you know someone that can look at it that actually knows what he's listening to??? i mean, i'm all for saving a few bucks but this sounds bad and is probably shot as others have said but its worth a shot to find out for sure.
Old Jul 14, 2012 | 11:29 PM
Centimetro's Avatar
Thanks for all the posts guys, appreciate every one. I didn't mess with it all today, was in mourning
Next step I definitely want to confirm that it's really toast. I guess I have nothing to worry about turning it on etc. at this point since if the damage is really done it's already too late, so tomorrow I'll try investigating the alternative theories here and try the screwdriver-stethescope trick that was mentioned before throwing in the towel.
Yeah, before pulling into the garage when it started outside it was actually quite a bit quieter so the garage really is amplifying the noise significantly
Not optimistic, but hopeful
unfortunately, no
Old Jul 16, 2012 | 06:14 AM
iflexsteel's Avatar
Ok this sounds like a ROD KNOCK. Meaning that you were low on oil or have none at all. Trust I've heard this sound before in another car that I've owned. Its always better to get a new engine cause it will cost you your chest to pay for it
Old Jul 21, 2012 | 10:49 AM
NoLimitsMaxiam's Avatar
Didn't read what everyone rote but my max had the same problem and it was just 1 of the timing tensioner that broke. I just put on a new and was good to go
Old Jul 22, 2012 | 12:32 AM
trust me, you were lucky!!!! thats why i say never let your oil get low by even a little bit as it will cause premature engine wear and cause you to do a 3.5 swap!!
Old Jul 23, 2012 | 04:30 PM
graff_hip_hop's Avatar
the tensioner took a dump.....first find out where the noise is coming from if is in the front where the front timing cover is most deff is the timing chain tensioner..
Old Jul 23, 2012 | 06:00 PM
andrewmac's Avatar
Well, that noise sounds a little familiar:
I just bought a new engine for $500 and swapped it.
Old Mar 15, 2013 | 11:40 PM
goddamn but people must beat the hell outta their maxes and never check the fluid levels. i'm at 243,000 and i know i got a tenshioner rattle, but i change the oil every 2,500 miles cause i know she leaks out of the timing cover and i get a louder rattle when i'm about a half a quart low. i also add bg moa oil additive to fresh engine oil cause it helps quiet her down and keep viscosity thicker under loads and at startups.
97_GXE
Sep 15, 2015 06:47 AM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
