New on here but having an issue with my ignition coils
Old Aug 6, 2012 | 03:41 AM
kgchris91's Avatar
I just changed my spark plugs and igntion coils recently because one in my rear was misfiring. Now i have 2 in the rear misfiring. I thought it were the coils but I switched em around and they checked out fine. What else could it be? Please help me out
Posted from Maxima.org App for Android
Old Aug 6, 2012 | 10:21 AM
AMP14's Avatar
Search this forum for your problem. I'm sure there are more threads on engine misfires than needed.
Your air/fuel ratio may be rich or lean causing the misfire. First thing I would do is check for trouble codes. Go to autozone for a free scan or use your ecu to find the codes.
Old Aug 6, 2012 | 10:32 AM
Amerikaner83's Avatar
When you changed out the coils and plugs, which plugs did you use? Also, could you have broken the boots on the coils in the rear? A bad connection to the coil could cause your misfiring issues.
Old Aug 10, 2012 | 01:48 PM
kgchris91's Avatar
I cant scan at auto zone since its a 95. it requires obd1. How do i use my ecu to do it? And its not the coils they r fine I checked but the plugs are a Nissan brand
Old Aug 10, 2012 | 01:51 PM
all 4th gens have obd-2.
So the coils are not broken..good. You said the problem happened when you changed plugs and coils, I just want to make sure you're not overlooking the obvious. Broken coil would be an easy thing to have.
"the plugs are nissan brand"...if you just changed them, do you remember what they were?
Old Aug 10, 2012 | 11:15 PM
DennisMik's Avatar
Checking/clearing ECU (CEL) codes, 4th gen Maxima
Old Aug 11, 2012 | 01:09 AM
max ride 41's Avatar
the plug for the obd2 reader is on the passenger side in our 95's btw.
PH98I30
20
Mar 25, 2020 03:44 PM
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
gustavison
Oct 4, 2015 06:50 PM
rnb754
Sep 14, 2015 11:39 PM
