MIL light on with no codes
Old Aug 11, 2012 | 01:05 PM
SVI30's Avatar
The MIL (check engine) light is on but my scanner didn't pick up a code. I can't erase any codes either.
What can cause the MIL to stay on?
Old Aug 11, 2012 | 01:16 PM
Amerikaner83's Avatar
Use a better scanner...the light will NEVER come on without a code.
Go to the parts store and get it scanned, then report back.
Old Aug 11, 2012 | 05:37 PM
AJCannon's Avatar
I came in to say the same thing. My scanner does not read codes from my Max for some reason either, but it'll read codes from other cars and other scanners will read my Max's codes. Get, or at least get access to, a better scanner and you'll be able to see the codes.
Old Aug 12, 2012 | 12:10 PM
DennisMik's Avatar
Just like when you are sick and the doctor says nothing is wrong - go get a second opinion.
Old Aug 12, 2012 | 03:32 PM
SVI30's Avatar
Went to the local Pep Boys and their scanner pulled P0153, O2 Sensor Circuit Slow Response Bank 2 (left/front). Looks like this was new for 1998 cars since P0153 is not in the 1997 FSM I have.
I should have asked them to clear the code and see if it comes back. My CodeKey reader can neither read nor clear the code. I went ahead and ordered a bluetooth type reader to see if it can read and clear this code.
A local shop fixed a leaky valve cover gasket and replaced the knock sensor a few weeks ago. They didn't "click" the cylinder 6 ignition module harness and it eventually came loose then the car ran on 5 cylinders for about 50 miles. May be all that fuel fouled up the O2 sensor. Cylinder 6 ignition module is under the pretty plate. I have no idea whether they did this on purpose or not.
Old Aug 12, 2012 | 03:41 PM
SVI30's Avatar
I was able to erase the code. I will drive it and see if it comes back. Thank you all for the suggestion.
Old Aug 12, 2012 | 05:48 PM
2brosgixxer's Avatar
For future reference, you can check and clear the codes yourself with no scanner by following this LINK
Old Aug 12, 2012 | 06:20 PM
DennisMik's Avatar
Go here and download the correct FSM:
http://boredmder.com/FSMs/Nissan/Maxima/
Old Aug 12, 2012 | 08:47 PM
SVI30's Avatar
Thanks, you guys are so helpful.
I did check the online copy of 1998 version and it does list P0153.
Old Aug 12, 2012 | 11:43 PM
You may find this link useful for checking code definitions. http://boredmder.com/ecucodes/index.php
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxima30
Sep 7, 2015 06:13 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
