95 Maxima electrical issues with turn signals relay/fuses and turn signal switch fine
Old Sep 18, 2012 | 12:41 AM
ace0fspadez0's Avatar
Yeah I took it to a mechanic who did free diagnostic work, he said the fuses and relay were fine, they even tried swapping out the relay with a new one and it didnt change anything. I ordered a new turn signal switch because thats what he recommended, but it acts the same as the old one did in that the headlights and all that work, but the turn signals do not.
One interesting thing is that the left foglight will turn on when I try to use the left turn signal, but the right one doesn't do the same.
My hazard lights work fine too, so its definitely not an issue with that. The issue started around the time when a worker at autozone decided to look at my steering column because the car wouldn't start. Could he have knocked a wire loose or something?
Old Sep 18, 2012 | 08:40 AM
Amerikaner83's Avatar
headlights work. Hazards work.
Fogs work properly? (aside from the fog turning on with the signal...)
have you done any parking light / foglight rewiring or anything to that effect?
Yes its possible that the autozone parts geek screwed something up, especially if the problem occured around that time.
Old Sep 18, 2012 | 09:55 AM
DennisMik's Avatar
You have an interesting problem. There is no normal connection between the fog lights and the turn signal, so somehow wires are being cross-connected. The wires for the brake light bulbs which the turn signals use do not go to the headlight switch which the fog lights use.
Does the fog light blink when you turn on the turn signal?
Inspect the wires on the steering column, paying close attention for damaged wires. You will have to get the wiring schematic and a volt meter and do some diagnosing.
Old Sep 18, 2012 | 06:58 PM
The left fog light stays on when I turn on the signal, but it doesn't blink. I know that when I was trying to replace the switch I had to get one that specifically had a connector for the fog lights, (so 3 connections in total) because standard ones wouldn't connect properly. So maybe that has something to do with it?
Old Sep 18, 2012 | 07:25 PM
Alright, on further inspection its not the left foglight that turns on.
Its hard to explain, but the headlights have two sections, and the section on the outside edge of the car on the left headlight gets brighter when I attempt to use that turn signal. The right headlight doesn't do this, and it may be the result of water damage as there is a decent sized hole in the glass of the messed up headlight. Anyone know what I should do in that situation?
Old Sep 18, 2012 | 09:45 PM
that's the clearance light, and thats NORMAL for 95/96 maximas.
You said water damage...that could cause your issues, sure. Shorting out the housing and what-not...bad juju. Time to get in there and take a good look bro. It could be something simple like the dual-filament bulb (1157) is bad.
Old Sep 18, 2012 | 09:49 PM
Have you tried a new 1157 bulb on the passenger side?
Old Sep 20, 2012 | 05:59 PM
Would that be the bulb for the clearance light or for the turn signal? Because the turn signals both work fine when I use my hazard lights.
Old Sep 20, 2012 | 06:17 PM
the bulb for the TURN SIGNALS is an 1156.
The bulb for the CLEARANCE LIGHT is an 1157. This is the one that's on dim with headlights, and goes brighter (and stays bright) when the turn signal is on.
Old Sep 20, 2012 | 11:27 PM
Ah alright, thanks for the info man.
Two more questions though if you don't mind. For one thing, the bulb does turn on, it just doesn't brighten like the drivers side one does with the turn signal. Could the issue still be the bulb? And two, would that actually have an affect on the turn signals not working?
Old Sep 20, 2012 | 11:39 PM
Maxima_Joe's Avatar
4th Gen Parts King
By relay do you mean they changed the flasher? If not then that's probably your problem.
Yes they tried a new flasher and that wasn't the issue. That was before they recommended getting a new switch.
Old Sep 20, 2012 | 11:50 PM
Maxima_Joe's Avatar
4th Gen Parts King
Next probable cause would be the hazard switch then.
Old Sep 20, 2012 | 11:51 PM
Hazard switch works fine, click it and all the turn signals blink and you can hear it in the flasher. So I'm not 100% sure that would be the issue.
Old Sep 21, 2012 | 12:05 AM
Maxima_Joe's Avatar
4th Gen Parts King
Different functions, The switch can be bad for turn signals and still work on hazards.
Old Sep 21, 2012 | 12:06 AM
Any idea how I would go about checking to see if thats the problem then?
Old Sep 21, 2012 | 09:15 PM
I replaced the clearance light bulb and that fixed that issue, my blinkers still don't work though. Any more ideas?
Old Sep 22, 2012 | 12:32 AM
Change hazard switch like joe mentioned.
Old Sep 27, 2012 | 08:41 AM
Just replaced the hazard switch, same issue. The hazard lights will come on but the blinkers still don't work.
Old Sep 27, 2012 | 11:37 AM
I guess at this point I should probably just take the car somewhere, unless you guys know of anything else to check.
Old Sep 27, 2012 | 09:16 PM
DennisMik's Avatar
Check all the bulbs in the turn signals and side markers. An 1157 bulb has 2 filaments in it and therefore has 2 contacts on the bottom of the bulb. An 1156 bulb has 1 filament in it and therefore has only one contact on the bottom od the bulb.
When I say check the bulbs, remove the bulb from the socket. Look at the bottom of the bulb and look at the bottom of the socket. The number of contacts have to match.
Also do this for the rear turn signal lights.
Old Jan 26, 2013 | 08:04 AM
Still having this issue, anyone know of anything else to try? Its down to it being a wiring issue at this point I think, but I'm not sure why a wire would've randomly come disconnected on its own
Old Jan 26, 2013 | 09:15 AM
DennisMik's Avatar
Since the turn signal lights illuminate when you use the hazard flasher, this says the wires are good. Since you replaced the hazard flasher switch, at this point the turn signal switch is suspect.
Do you own a voltmeter of a test light?
Old Jan 27, 2013 | 10:09 AM
Sadly no, but I already replaced the turn signal switch and that wasn't the issue either. The FSM says in this situation if it isnt the fuse, switch, or hazard switch to look for an open in the circuit. So I guess I need to just get it looked at.
ah2002
Mar 9, 2016 01:42 PM
Finkle
Sep 27, 2015 09:53 PM
Samedi
Aug 13, 2015 04:05 PM
kjm900r
Aug 5, 2015 07:14 AM
maxima297
Aug 3, 2015 12:50 PM
