bearing shavings in oil.
Old Sep 18, 2012 | 05:22 PM
TravisCadello's Avatar
changed oil i ran around 5500 miles on mobil 1 high milege oil and mobil 1 oil filter..Stupid i know but been really busy, anyways shes at 250k miles and has always ran mobil 1 since 200k miles. but when i changed oil i found a good amount of metal shavings together at bottom of oil drain pan.
now with clean motor oil but with k and n oil filter i just checked oil and at bottom of stick is a little shavings everytime i clean it and stick it back in,motor runs great and sounds great.
Should i be getting ready to replace motor soon?
Old Sep 18, 2012 | 07:48 PM
asand1's Avatar
Mobile 1 should be good for 7000+. Sounds like motor is not happy. Is it aluminum or steel? Stick to a magnet?
Old Sep 18, 2012 | 08:20 PM
Kuhn_man's Avatar
new engine lol but nothing wrong with 5000 miles on mobile 1
Old Sep 19, 2012 | 07:03 AM
cashoit's Avatar
I would. Sorry man.
But what is the engine doing? Misfiring? louder? Its an aluminum block so, yea man, i wd start saving up.
If you have the time and skills, pop open valve covers and take a look.
Old Sep 19, 2012 | 08:27 PM
No Magnents so im not too sure what it is.. But theirs a Tapping noise from the rear head. But im pretty sure the rod bearings or mains are thin and about to start knocking.i pray not but the shavings look like rod bearing material.
Old Sep 19, 2012 | 08:28 PM
It's been highly abused.
if i bought a 04 maxima motor what would need to be done to get it running in 99?
Old Sep 20, 2012 | 01:44 PM
Snypa's Avatar
Is smoke coming from your oil filler cap?
Old Sep 20, 2012 | 01:56 PM
ShocknAwe's Avatar
Magnetic drain plugs on an older engine are never a bad idea. Can nip catastrophic failure in the bud before it happens
Old Sep 21, 2012 | 08:00 AM
Rob_0126's Avatar
would a napa magnetic drain plug be good?
some have the copper seal, others rubber.
OT: sound like the engine is breaking down, especially hearing a rod knock.
Old Sep 22, 2012 | 02:35 AM
No Smoke from oil filler cap and its deff not a rod knock i hear lol Not yet at least its the sound of a loose lifter in the rear head rattling......Today i put in some THICKK Stop Smoke **** and the noise went away completely guess older engine needs a thicker viscosity oil?
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
