Question on Strut mounts
Old Oct 2, 2012 | 06:01 PM
TreizeRXH's Avatar
Ok fellas soooo...
Just changed my rear struts, all with new hardware minus the strut mounts. Now my question is, is there a specific direction in which the strut mounts should be bolted (like is one side supposed to be "out") or is the clunking I'm now hearing a result of completely F'd strut mounts??
Old Oct 2, 2012 | 06:04 PM
ShocknAwe's Avatar
Look from the trunk, is the top of one of the struts up higher than the other? You might need to get a washer and slide it down the strut shaft until the little stopper when the bushing is supposed to sit and then put the bushing on. Most likely the strut shaft pushed through the bushings and is now clunking
Old Oct 2, 2012 | 06:30 PM
TreizeRXH's Avatar
Do you think it'd be the case for both strut mounts? I'm certain I'm hearing the clunking on both sides
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
