No spark cylinder #2 and #5
Old Nov 10, 2012 | 12:41 PM
95crackedhead's Avatar
Greetings all. I have a 1999 Maxima that will not start. I've read all the stickies and done some searches but haven't found what I'm looking for.
Current ECM codes are for knock sensor and AIT. I don't think those would prevent the car from starting though?
I bought the car with a rough running engine several months ago. I did a compression check back then and all seemed fine with all 6 cylinders at or near 190 psi.
I noticed that pulling the ign coil connectors on #1 and #2 didn't have an effect, so I figured I would swap in new coils and call it a day. I bought the car and tried to drive it home. At idle the car sounded OK except for a small misfire and would rev nicely while standing still. When driving though, the car couldn't get past 2500 rpm without slowly bringing the revs down to almost stalling. Sometimes it did stall. But the car would always crank over and start again. It got to a point where the car wouldnt start and I had to have her towed home.
The car then sat for about two weeks, and did start up again first try. But the fuel cut issue happened again, stalled the car and I haven't been able to start her since.
Things I've tried:
-Recharge battery
-Tried jumpstarting the car
-Checked PCM feedback signals on all 6 coils (all present) when cranking
-Checked power and ground to all 6 coils and also no shorts on the PCM signal lines on all 6 coils.
-Swapped known good coils to #2 and #5 with no effect. (Problem stays with the cylinder)
-Checked Crank POS and REF harnesses and sensors per FSM. Both good.
-Checked CAM sensor while still mounted in timing cover. Checked OK.
I'm in the process of adding more grounds to trans case and starter mounting bolt.
Is there anything that would cause a coil to not fire but the signal and power connections are present and operating correctly?
Old Nov 10, 2012 | 01:53 PM
DennisMik's Avatar
It could be the crank shaft sensor at the flywheel, CKPS(POS). Worst case it could be that the timing chain has jumped a tooth.
Old Nov 10, 2012 | 04:50 PM
Just added a ground direct from Batt. negative terminal to the trans case bolt near the CKPS POS. I now get spark on all 6 cylinders. Will update if she starts.
Also got to get a proper cable. I'm using two 10 ga. romex conductors twisted together - it's all I had on hand to test with.
Old Nov 10, 2012 | 05:08 PM
maxed_out_99's Avatar
You sure it's spark related? What do your plugs look like?
Old Nov 11, 2012 | 07:49 AM
plugs are black and wet with gas.
I tried starting her up after I got all cylinders to spark. Still wouldn't start. I'm thinking it's flooded, gonna try to clear flood it later today.
Old Nov 11, 2012 | 02:24 PM
You need injectors dude
Clean off the plugs real good reinstall them. Then pull the fuel pump fuse and crank it over. If it fires stumbles and dies then spray some carb spray in the throttle body if it runs then dies your injectors are shot
Old Nov 11, 2012 | 03:03 PM
asand1's Avatar
I was also thinking injectors. Possibly just o-rings even.
Old Nov 11, 2012 | 04:44 PM
MAXIMA_STYLE's Avatar
screw injectors...just get an 00vi setup and swap it all out
Old Nov 11, 2012 | 09:27 PM
2-3 bones for injectors at a junk yard and the whips running compared to 2-300 for the swap plus down time.
OP do what you can afford
Old Nov 12, 2012 | 05:43 AM
darrick's Avatar
Dallas Nissan Enthusiast
just went through the same thing on my 99, swap of the fuel rail and all was good.
Old Nov 13, 2012 | 06:46 PM
Alright, I sprayed starting fluid into a vacuum hose coming off the airbox and got her to fire up. Started instantly, and ran for a couple seconds before dying.
Next was a fuel pressure test at the outlet of the fuel filter. I got no gas leakage when taking the line off and absolutely no pressure when gauge connected and cranking for a few seconds.
Also the fuel pump is making a high-pitched whining noise when the ECM commands it on for the first couple seconds when the key goes to "ON".
For now I'm thinking fuel pump is toast. Seems to have died a slow death.
Old Nov 13, 2012 | 06:48 PM
As much as I'd like to do the upper intake swap, I kinda don't want to keep the car. My map sensor harness +5v power wire is not working. The wire is brittle as all hell and broke when I just about breathed on it. Who knows what the condition is of all the other wires in that main EGI harness.
Old Nov 16, 2012 | 08:16 AM
CMax03's Avatar
injector orings partsgeek.com IIRC $3.10.....or injectors (rebuilt as low as $26)
jmlee44
Oct 2, 2022 02:13 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
