Cold start issue
Old Nov 12, 2012 | 05:28 PM
mrkhone's Avatar
Cold start issue
I just had the car for a couple of months. Now since it's getting cold it doesn't start easily. When I start it it'll die out unless I give it a little gas. I'm most sure what it is.
Old Nov 12, 2012 | 10:22 PM
DennisMik's Avatar
If the car starts and runs fine when the engine is warm, it might be the ECTS - engine coolant temperature sensor.
Old Nov 15, 2012 | 09:27 PM
Trini Boom's Avatar
^^This or FPR (Fuel Pressure Regulator)
Old Nov 16, 2012 | 05:11 AM
njmaxseltd's Avatar
Check the resistance of the ECTS when it's cold. Make sure it's within spec.
Check the cold idle plunger and linkage, make sure it's opening the throttle body when it's cold.
Clean the throttle body and IACV.
Old Nov 16, 2012 | 06:46 AM
CMax03's Avatar
More than likely the ECTS or it's harness! Fuel injection just doesn't work to well when the sensor that it relies on during "Cold open loop" operation is faulty! If your not sure grab one, two or three from your local boneyard and swap out.....they fit in the pocket wel!
Old Nov 16, 2012 | 05:26 PM
mrkhone's Avatar
where can i find the ects sensor at
02PearlSE
Oct 7, 2015 02:12 AM
bc992164
Aug 26, 2015 12:19 PM
FlaMark
Aug 21, 2015 11:06 AM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
