Removing Spark Plugs
Old Jan 10, 2002 | 10:27 AM
SuDZ's Avatar
Hey,
I was changing my spark plugs the other day but had a problem with one. It is the one on the top right. I moved everything out of the way and had space to work with but had one problem. It seemed that my socket was not holding it good enough to get it out of the whole. I got all the others out but this one would not grip it enough or somethign so when I undid it and tried to pull it out , it was left behind in the shaft.
Does anyone have any particular tips for getting it out of there? Any suggestions?
SuDZ
Old Jan 10, 2002 | 10:30 AM
Sprint's Avatar
put electrical tape over the socket and attachment
Old Jan 10, 2002 | 10:34 AM
SuDZ's Avatar
Like on the inside of the socket?
SuDZ
Old Jan 10, 2002 | 10:39 AM
Sprint's Avatar
SuDZ
no.. you know the long attachment that goes in the socket.. tape from the bottom of the attachment over the socket.. so it holds it firmly in place..
Old Jan 10, 2002 | 10:40 AM
multiplexor's Avatar
SuDZ
i changed my spark plugs last night actually, alof with the STS install ;-) heh
I used a magnet to pull out the sparkplug. the magnet was attached to a moveable type wire. Something you could probably pick up at any autoshop. OR... you could make yoru own.. just a string with a magnet attached to it.
Old Jan 10, 2002 | 10:42 AM
SuDZ's Avatar
Cool. I was thinking the same thing with a longer pair oof tweezers or something.
Thanks Guys
SuDZ
Old Jan 10, 2002 | 10:44 AM
Sprint's Avatar
Thanks Guys
SuDZ
oh sorry.. you left the socket in the hole.. um.. when that happend to me.. i put the attachment back in the hole.. shaked it around a little bit.. then loosened the spark plug and then it came back out..
Old Jan 10, 2002 | 10:47 AM
SuDZ's Avatar
Cool. I can try that right in the parking lot on lunchbreak. Maybe I will try that before buying the magnets or whatever first.
SuDZ
Old Jan 10, 2002 | 10:51 AM
SuDZ
yeah good idea if not, then a handy magnet stick type thing could always be handy
weird but that's the spark plug which had alot of oil on it when i pulled mine out. All the others seemed fine.
Old Jan 10, 2002 | 10:54 AM
SuDZ's Avatar
Mutiplexor, that may not be a very good thing.
You might want to check out this thread I found for you as an FYI
http://forums.maxima.org/showthread....oil+spark+plug
SuDZ
Old Jan 10, 2002 | 11:01 AM
SuDZ
arg!
One guy mentionned that it might not be good to drive on it like that for months.... uhm off the top of anyones head... any idea how much that would cost to fix? I'm assuming i would have to replace the gasket and that's pretty much it, if i even tried to do it myself...
Oh, Thanks a bunch SuDZ for helping me find that thread. I did a search before, but never came accross it.
Old Jan 10, 2002 | 11:05 AM
Sprint's Avatar
i had oil on my plugs.. but the diff is.. i know my engine is fu@ked
Old Jan 10, 2002 | 11:13 AM
last oil change i also changed to pure synth. I'm wondering if that had anything to do with it... car has about 83,000 miles on it.
Old Jan 10, 2002 | 11:59 AM
SuDZ's Avatar
Thanks for your help guys. I just ran out on my lunch and changed those last stuck plugs. I ended up using one of those mechanical claw type thing I found at the hardware store up the street. I'm Glad I am no longer running on 4 plugs new and 2 old ones.
SuDZ
Old Jan 10, 2002 | 12:09 PM
SuDZ
Cool!
Good job, atleast your runnin full new ones now.
Old Jan 10, 2002 | 01:09 PM
SuDZ's Avatar
Cool!
Yeah and since they are supposed to be good for like 70K or so Shouldnt have to worry about them again. Are you gonna do anything to look into your oily plugs?
SuDZ
Old Jan 10, 2002 | 01:21 PM
gtr_rider's Avatar
192.168.1.1
tape does the trick, eh?
Old Jan 10, 2002 | 01:41 PM
Sprint's Avatar
well he wouldn't have been in this pickle if he did it that way to begin with
Old Jan 10, 2002 | 01:53 PM
ejj's Avatar
ejj
To make this job even easier...
I was in sears the other day browsing the tools, and I found the perfect tool for this. Its basically a telescoping pointer that you'd think of teachers using with a magnet on the end. I got the smallest one that they had, which they claim can hold up to 8 pounds or something like that. More than enough for a spark plug.
All this for only $2.99!
max808's Avatar
How long extension?
How long extension did you guys use? I just bought a 10" from Sears but am not sure if it's long enough? First time changing plugs. The next length up is 20" and that seems way to long.
Old Jan 10, 2002 | 01:59 PM
SuDZ's Avatar
Re: How long extension?
10 inches should do it. I used like a 6inch on the fronts and on the backs it was deeper so I added around another 3 inch onto that one. Your ten should get all the way down but on the pack, the one furthese to the right, move some of the stuff out of the way on top by unbolting and unplugging it. If you do it will give you plenty of extra space to move around in.
SuDZ
Old Jan 10, 2002 | 02:01 PM
Sprint's Avatar
i think mine is 10" the extension is 2 inches shorter than my *****
Old Jan 10, 2002 | 02:03 PM
SuDZ's Avatar
Re: Re: How long extension?
Very frightening information your giving out today Sprint.
SuDZ
Old Jan 10, 2002 | 02:10 PM
hmm TMI
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
Need help
23
Oct 2, 2015 08:56 AM
zmcneely13
Sep 26, 2015 02:26 PM
