Massive Napa gold 1182 oil filter
Old Jan 13, 2013 | 05:59 PM
asand1's Avatar
Today I got tired of trying to pass a mini game on Zelda and decided to trial fit my Napa Gold 1182 filter.
I had to remove some material with my Chraftsman angle die grinder. After removing some aluminum from above the pan rail gasket area it barely scrapes just enough to remove some paint from the can.
I then applied some of my daughters paint to the filter gasket and installed the filter. Sealing area looks great to me.
Luckily I was over full 1/2 a quart so removing and reinstalling the filter was not a big issue. All grinding was done with the small filter in place and then sprayed with brake cleaner and then air prior to removing the filter again. The car was not run with the 1182 filter, that will wait until the oil change in about 1.5K.
Wix 57356 maxima filter
Style:Spin-On Lube
FilterService:Lube
Type:Full Flow
Media:Paper
Height:3.402
Outer Diameter Top:2.685
Outer Diameter Bottom:Closed
Thread Size:20X1.5 MM
By-Pass Valve Setting-PSI:8-11
Anti-Drain Back Valve:Yes
Beta Ratio:2/20=6/20
Burst Pressure-PSI:363
Max Flow Rate:9-11 GPM
Nominal Micron Rating:21
Wix 51182
Style:Spin-On Lube Filter
Service:Lube
Type:Full Flow
Media:Paper
Height:5.207
Outer Diameter Top:3.66
By-Pass Valve Setting-PSI:24
Burst Pressure-PSI:350
Max Flow Rate:7-9 GPM
Acording to the guys at Bob in The Oil Guy, this filter will outflow a VQ by sometiing like 5X.
Old Jan 13, 2013 | 06:59 PM
ABIGBRAIN's Avatar
I thought you were going with the 51344?
Old Jan 13, 2013 | 07:03 PM
asand1's Avatar
The minimal gain in size was not worth $12 for a paper filter. I decided to try this one.
Old Jan 14, 2013 | 06:58 PM
iDuty's Avatar
Do you plan to run this filter for an extended interval to take advantage of the additional filtering media inside?
Old Jan 14, 2013 | 07:08 PM
asand1's Avatar
With the larger media and added oil capacity I will go from 3k to 5k.
Old Feb 2, 2013 | 05:29 PM
asand1's Avatar
I went ahead and changed the oil 641 miles early today. Startup was as quiet as any other startup after an oil change.
The reason for the larger filter is two-fold. Both reasons are related to the extra oil capacity.
1 I like the idea of using the whole 5qt jug rather than having extra oil take up space in my small garage.
2 I feel better about stretching the OCI to 5K+ with the extra .75qt.
As far as being a dead ringer, the bypass is 24 rather than 8-11, but with the larger media I believe the pressure differential will be close to the same.
Old Feb 11, 2013 | 09:19 AM
asand1's Avatar
Ok not so good news. Napa 1182 + 49* X 3000RPM = rattling.
Next I will try a 1347 with 8-11psi bypass.
Old Feb 11, 2013 | 09:59 AM
dwapenyi's Avatar
OK, devil's advocate.
The engine rattles when the oil pump is spinning strongly at 3K rpms. Not a good sign. This would suggest that, if you downgrade to a smaller filter, one that is still bigger than OEM, and the rattle goes away, BUT, would you not remained concerned that oil is not getting as much oomph going through all those oil passages as the OEM filter for the very same reasons?
Yeah, no rattle, but still. Fact is, from your first experiment, the bigger filter is robbing pressure or flow or what have you.
Perhaps a beefier, faster pumping oil pump is in order as well. But then that gets real complicated I imagine.
Old Feb 11, 2013 | 10:01 AM
Fakie J Farkerton's Avatar
Nothing is wrong with the stock size.
Your not helping your car or yourself.
Just stick with the right one!!!
Old Feb 11, 2013 | 11:39 AM
asand1's Avatar
The 24psi bypass valve is starving the engine for oil until warmed up and thinned out.
Old Feb 11, 2013 | 03:49 PM
ABIGBRAIN's Avatar
Seems the 51344 is looking more and more like a worthwhile investment.
Old Feb 11, 2013 | 05:49 PM
asand1's Avatar
I went ahead and installed a 1347.
Here's the Oil Filter's specs:
Part Number: 51347
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 325
Max Flow 9-11 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Borrowed this pic from my 350z
Old Feb 11, 2013 | 06:06 PM
dwapenyi's Avatar
So you're saying that your revved your cold engine to 3K rpms and heard the rattling? What kind of oil are you using, dino or synthetic? 10W30?
Old Feb 11, 2013 | 06:32 PM
asand1's Avatar
Yes, at 49 degrees I waited till 3K to shift into third. I am running 5W30 Castrol GTX. This was never a problem with a stock type filter.
my03maxima
Jul 28, 2024 07:40 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
Justin Kroll
Oct 1, 2015 07:03 PM
