Rear view camera reverse light circuit??
Old Jan 20, 2013 | 05:11 PM
TSoprano's Avatar
To those of you with a dvd headunit with rear view camera installed..
Where's the best place to pick up the reverse light circuit to plug into the headunit??
I have a 5 spd.. Is there an easy place near the trans to tap into it? Or is it easier to tap in @ the reverse light bulbs and run it up with the video cable??
Old Jan 21, 2013 | 12:43 PM
bobflood's Avatar
The neutral/reverse switch is on the driver's side, top of the transmission toward the back of the engine compartment. There is a two wire plug attached - one green wire and one green/white wire. The green/white wire is the one you want to use. It goes thru a connector into the passanger compartment, then thru the main body harness that runs up the driver's side of the car to the back -- it is green/white all the way to the back-up lamp sockets on the trunk. Good luck.
Old Jan 21, 2013 | 12:46 PM
TSoprano's Avatar
Thank you! Much appreciated!
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
BobMax
Aug 19, 2015 04:39 PM
spidgeon
Aug 18, 2015 05:46 AM
Derrick2k2SE
Aug 12, 2015 06:47 PM
