Front Jack Point
Old Feb 15, 2013 | 09:43 PM
wxm's Avatar
wxm
Front Jack Point
My 95 GLE has some rust on the lower radiator support, pretty common problem for the 4th gen max. It is not too bad and doesn't like it is breaking off anytime soon. But it worries me every time I jack up the car using the front jack point (the one at the center bottom behind the bumper) as I put all the front weight to the single point. Could anyone confirm that the jack point is supported by the lower radiator support (at least partly) ?
Thanks in advance.
Old Feb 15, 2013 | 11:41 PM
Rods03Max619's Avatar
A thread on Jack points may help...
http://forums.maxima.org/4th-generat...99-maxima.html
or images
https://www.google.com/search?hl=en&...t%3B867%3B1197
Old Feb 16, 2013 | 05:39 AM
wxm's Avatar
wxm
Thanks for the picture and the link. It is the front jack point in the picture. Is it supported by the radiator lower support?
Old Feb 16, 2013 | 05:58 AM
njmaxseltd's Avatar
Yes, if yours is rusted, don't use it.
Old Feb 17, 2013 | 04:07 AM
wxm's Avatar
wxm
Thanks, where do you use to jack up the front then?
Old Feb 17, 2013 | 07:04 AM
jholley's Avatar
Before I replaced my cracked lower radiator support I placed the raising jack on the back end of the crossmember bar where it mounts onto the chassis.
Old Feb 18, 2013 | 03:17 AM
Zach-R's Avatar
When I bought mine I jacked up my car using that cross member. I stopped once I realized and heard all the cracking. Low and behold I had the infamous core support rust. Car was down for a while after that. If your core support is healthy there shouldn't be an issue.
Old Feb 18, 2013 | 03:48 AM
wxm's Avatar
wxm
So where did you use as jack point if not the cross member?
Old Feb 18, 2013 | 06:44 AM
Zach-R's Avatar
There's two tow hooks in the front. I usually use them.
AcuraLegend
Oct 17, 2016 08:47 PM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
jfl330
Sep 4, 2015 01:44 PM
