99 Maxima outfitted with the full 01 DEK
Old Feb 27, 2013 | 05:37 AM
max1008's Avatar
Ok guys I got the motor in last week and doing some work/cleaning before the install..oh yeah and turbo. I've done some research and I've found OOVI swaps in details but not a Full DEK swap but from reading this is what I found that needs to change (add please or help and point me to the how to):
pigtails need to be changed for the injectors
blockoff plate and adapter plate for the IACV (to use the 4th gen IACV with the 5th gen TB)
I'm going to remove swirl valves
I'm going to remove butterfly so no need for an RPM switch
TPS sensor pigtail on the 4th gen harness needs a little altering to fit on the 5th gen TPS
adding a VFAC2 for fuel/air control
Aeromotive A1000-6 Injected Bypass Regulators
Any help if I'm missing something. I plan on tearing into this over the weekend and replace gaskets and start painting parts.
Old Feb 27, 2013 | 05:41 AM
max1008's Avatar
LOL found some a thread
http://forums.maxima.org/all-motor/5...p-dummies.html
Old Feb 27, 2013 | 05:50 AM
matts95max's Avatar
Im in the same boat as you. DE-K swap in my 95. Except I kept the butterflies and have an rpm switch that I need to install. And I dont have boost, unfortunately.
I also need something for tuning A/F. Was thinking the VAFC 2 as well. Keep me informed of your progress/problems and ill do the same.
Old Feb 27, 2013 | 06:33 AM
max1008's Avatar
Will do man. I'm just now starting this and will go to the junk yard this weekend for the pig tails to wire up. I'm trying to follow a mixture of the dummies thread and the OOVI swap thread. It's so disorganized. My main concern is the vaccum lines. There is a thread on hooking up a VFAC (http://www.vqpower.com/v3/how-tos/electronics). Hope that helps you.
Old Feb 27, 2013 | 06:38 AM
aackshun's Avatar
In regards to the vacuum lines just block them all off
But if you want no codes then.....
You have a 99 so it's pretty obvious which ones you need and don't need.
Things are tricky for 95-98's though.
Old Feb 27, 2013 | 07:10 AM
matts95max's Avatar
Thanks for that link, I will def check it out. I have already done my swap. I just havent done all the other stuff. I know after doing my swap I had vacuum leaks. They werent hard to find when the motor is running
Old Feb 28, 2013 | 05:19 AM
max1008's Avatar
Did you use the DEK EGR, do they plug right in to not throw a code? Right now I have my motor at one place and my car at another so I can't compare.
Old Mar 2, 2013 | 01:23 PM
RA030726's Avatar
I'm nutty for Nissans
99's use an electronic EGR valve. It may be the same as the DEK setup and plug in. I know the 95-98 EGR just needs the valve to manifold tube and temp sensor swapped over.
I'm in the middle of a 00vi swap myself. I have the DEK motor on a stand. Most of it really is a bolt on affair.
Old Mar 2, 2013 | 03:35 PM
CMax03's Avatar
Once this is done how much power is usually gained at the wheels?
Old Mar 2, 2013 | 04:24 PM
MAXIMA_STYLE's Avatar
Depending on supporting mods to go with it and a tune....around 30whp iirc
Old Mar 2, 2013 | 05:04 PM
schmellyfart's Avatar
Actually it's not tricky at all.
http://www.flickr.com/photos/schmellyfart/8517741406/http://www.flickr.com/photos/schmellyfart/8517741406/ by http://www.flickr.com/people/schmellyfart/, on Flickr
Old Mar 3, 2013 | 09:19 AM
RA030726's Avatar
I wonder who wrote that? I'll have to take a pic of my simplified vacuum setup.
Old Mar 3, 2013 | 02:01 PM
The only thing I had to change on it was B and C for the EVAP solenoid. My car and all of the 4th gens at the junkyard had the check valve on B and the purge control valve on C.
Old Mar 5, 2013 | 06:55 AM
max1008's Avatar
Old Mar 5, 2013 | 06:57 AM
max1008's Avatar
Friend of mine looking over the motor
Old Mar 5, 2013 | 06:58 AM
max1008's Avatar
Old Mar 5, 2013 | 07:01 AM
max1008's Avatar
and the color choice is....
Old Mar 5, 2013 | 07:09 AM
max1008's Avatar
So I've taken out the swirl valves and sent the injectors off to be tested and cleaned. I'll be running (if everything goes eight with this sale) a disco potato (Garrett GT2860RS turbo)...My new Megan dual tip muffler came in with 3 inch piping..just need to get some bends and that should be taken care of.
Im really concerned with the Vaccumm lines and EGR issue (the 2001 doesn't have the tubes thank god)..I just feel it's going to be a huge mess. But maybe I'm just overlooking at it and I'll worry about it when I get to that point. I still need 3 5th gen injector pigtails so the junk yard this weekend..
Old Mar 5, 2013 | 12:51 PM
RA030726's Avatar
Yup looks like you're right. I still have my hand written diagram of the solenoids. Must have been cross eyed by that last one.
Old Mar 11, 2013 | 05:15 AM
max1008's Avatar
So over the weekend I decided to paint the block and heads..whatcha think?
Old Mar 11, 2013 | 05:22 AM
Zach-R's Avatar
Lookin good. What color is the car it's going into?
Old Mar 11, 2013 | 05:31 AM
max1008's Avatar
pearl white
Old Mar 11, 2013 | 07:57 AM
BlackThornDemon's Avatar
What color is that orange?
Old Mar 11, 2013 | 08:28 AM
max1008's Avatar
Burnt Orange..
Old Mar 11, 2013 | 04:08 PM
whitemax21's Avatar
I hooked up my evap according to this diagram. You mention here that the 4th gens at the junkyard have the check valve going to B and the purge valve going to C. Is the diagram correct or do I need to switch B and C?
Old Mar 11, 2013 | 11:32 PM
I'm 99% sure the image up is the correct one, not sure what happened when I typed that response. I removed the older incorrect image from my Flickr account. I'll double check my setup tomorrow and let you know.
Old Mar 12, 2013 | 10:50 AM
The image is correct, my check valve is on C. I think I meant to say that when JSutter originally wrote it, that's what he had listed for B and C.
Old Mar 12, 2013 | 11:45 AM
whitemax21's Avatar
Ok. Thanks for checking.
Old Mar 12, 2013 | 08:56 PM
No problem.
Old Mar 14, 2013 | 10:56 AM
Nice color choice... I have the same colors... Mine is bt4 though.. As i stand right now i may be dek swapping shortly as well.. Not 100% sure yet... I may have a leaky headgasket and rather than fix it.. I will most likely swap engines as i can get my hands on a dek with 100k even for 250 bucks.. My concern is only with vac lines and egr mainly.i have a 97 engine in my car now so im in a diff boat
Old Mar 14, 2013 | 03:35 PM
RA030726's Avatar
Not the best pic but here it is simplified Attachment 34614
Old Mar 16, 2013 | 12:13 AM
Nice, did you trim your map sensor at all? Mine looks about twice as large as the one you have.
Old Mar 16, 2013 | 07:57 AM
RA030726's Avatar
No, in 98 they changed them.
Old Mar 17, 2013 | 02:15 PM
Damn, looks like i will be getting myself into something more than i planned for...i got a 99 that i will be dropping a dek in...i thought the only things i needed to worry about were the injectors and adapter plate for iacv..and removal of swirl valves....
Old May 13, 2013 | 09:09 AM
max1008's Avatar
OK so motor pulled:
Bolted everything and swapped over to the "new motor":
Old May 13, 2013 | 09:10 AM
max1008's Avatar
another angle:
Wife decided to have fun:
Old May 13, 2013 | 09:12 AM
max1008's Avatar
And the new motor going in the car:
Old May 13, 2013 | 09:13 AM
max1008's Avatar
Put the front back together and this is how she will sit for a little while:
Old May 13, 2013 | 09:15 AM
max1008's Avatar
Here is the list I have to still do:
injectors cleaned and tested
feed pipe and down pipe for turbo fabbed
finish intercooler piping
fuel pump
APR - aeromotive
oil cooler
z32 MAF
VAFC2
Still a lot to do before she is back on the road!
Old May 13, 2013 | 09:19 AM
max1008's Avatar
Oh yeah and I bent the shift control rod assembly when taking the engine out...Called Nissan and they want $114 for the part...not too bad. 5sp are hard to find in the junk yards.
Quickgtp
Apr 13, 2017 03:30 PM
Balkins
Feb 1, 2016 12:45 AM
maxinout93
Oct 27, 2015 01:29 PM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
Blackwind
Aug 5, 2015 06:35 PM
