interior light fuse keeps blowing???
Old Mar 7, 2013 | 06:24 PM
maxinout93's Avatar
95 max yesterday i noticed my interior light fuse keeps blowing everytime i replace it and turn on the light switch at night. it is labeled int. illu on the fuse panel under the dash. i tried searching but no luck, so i replaced the dimmer switch, and the fuse, but it still blows, all other lights, headlight, fogs, door lights, maplights and a/c lights work. the cluster, shifter, and power window switch lights dont work without that fuse working. only thing i did to the cluster is add sum green led lights, and jus added sum fog lights, but the leds were installed months ago, so i dont kno why the fuse keeps blowing.
Old Mar 7, 2013 | 06:36 PM
tigersharkdude's Avatar
something is grounding out and causing the fuse to pop.
What kind of fogs did you add ,and how did you wire them up?
Old Mar 7, 2013 | 08:06 PM
maxinout93's Avatar
i added oem fogs and used the stock wiring, and got a oem stalk to turn them on and off with the regular lights
Old Mar 7, 2013 | 09:57 PM
DennisMik's Avatar
Maybe one of the leds you put in the cluster shorted. Take them out and see if the fuse still blows.
Old Mar 8, 2013 | 12:12 PM
maxinout93's Avatar
Yah u may be right man, a few weeks ago, one of the cluster lights went out on one side, but I didnt pay any attention to it, then a few days ago, i noticed on one side of the cluster, the lights would brighten and dim on and off. So i guess Ill have to remove it and see whats going on.
Maxima30
Sep 7, 2015 06:13 PM
jds22
Sep 4, 2015 01:52 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
