center dash drawer broken??
Old Mar 16, 2013 | 01:51 AM
max ride 41's Avatar
the one underneath my stereo in my 95 that you push in to lock it in and push for it to come back out. it got stuck and i had to pry it open, well, it won't push in and stay shut anymore. do i have to replace or is there a way to fix it?
Old Mar 16, 2013 | 01:57 AM
Fakie J Farkerton's Avatar
Subscribed.
Old Mar 16, 2013 | 12:15 PM
Nugent20's Avatar
there are 2 tracks that run along the sides of the pocket, 1 of the tabs may broken that runs along the tracks but usually when you take them out by removing the radio trim panel you can tell what's busted
option B is to purchase 1 from a junk yard from a Maxima or I 30
Old Mar 18, 2013 | 09:25 AM
milo2223's Avatar
Go with option B they are cheap and easy to find...
Old Mar 18, 2013 | 11:59 AM
Nugent20's Avatar
Exactly, mine has jammed a few times and been corrected. But I still bought a couple just to have...pm if needed
Old Mar 18, 2013 | 04:06 PM
now you tell me!! i just went to the junkyard and found one that matches my car exactly out of a 97. can you lube the sliders to make them work better? also, is there a quick write up to pull this out? i noticed in the j/y car that it was attached to the upper piece with the stereo. i've seen my h/u out when it was being installed, looks like a bit of a headache. also, what broke is the little white plastic locking piece in the back, slides out and in fine.
Size:  73.3 KB Name:  DSC_0517_zpsd9abc388.jpg
here's the back of it and the clip i was talking about.
Old Mar 18, 2013 | 04:56 PM
Nugent20's Avatar
Pretty easy removal. Pry up the surround around the shifter. Remove screw from ashtray. Pull out heater vents (with buttons). Remove 4 screws holding in radio bracket and dash housing.
That white plastic clip to close drawer is finnicky, I'd swap it out.
Sorry, on a tablet now, but I know there are good links/videos ( YouTube) for maxima radio removal
Old Mar 18, 2013 | 05:19 PM
you can't swap out the plastic clip, they don't just make it seperatley. i need pics of this, i took it apart b4 and the bottom comes out easy, the top is a bit more of a pita.
Old Mar 18, 2013 | 05:27 PM
Nugent20's Avatar
I meant swap whole pocket, not just the clip. What bottom and top are you referring to?
Old Mar 18, 2013 | 05:31 PM
Nugent20's Avatar
http://www.shareamemory.com/radio/maxima96/
Figure 14 shows the two screws (on each side) which hold the entire pocket.
Old Mar 18, 2013 | 06:07 PM
bottom and top of dash, it's not a 2 minute swap out. you gotta unplug the cig lighter and there's a few screws that gotta come out. i've never taken the whole dash apart b4 and i'd rather not for this. the guy who installed my stereo/ hu can probably do this in like 10-15 minutes.
Old Mar 18, 2013 | 07:38 PM
Nugent20's Avatar
Yes, def only a 10-15 min job. And def not the entire dash. That took an hour!
Old Mar 18, 2013 | 09:02 PM
i meant just the center, not the entire dash. i had a double-din installed and figure my guy can do it easily. i would like to watch him so i can do myself next time.
Old Mar 19, 2013 | 08:06 PM
Nugent20's Avatar
Definitely! If I was closer, I'd help (Akron area)...
Time to put those 4k posts to use and start wrenching!
Old Mar 19, 2013 | 10:13 PM
you and your silly 47 posts....
Old Mar 20, 2013 | 05:30 PM
Nugent20's Avatar
Haha, I'm working on it! I swapped engines with 20 posts! Albeit, with 12 codes left to clear.....
Cheers
Old Mar 20, 2013 | 06:59 PM
Cheers
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
